02 GT will not start
I've been reading the forum for a while, and finally have a reason register and post. I have an '02 GT that will not start. A month ago I had the same problem. The starter has been replaced, and all seemed fine. Today at work, the car wouldn't start again. I have a good charge from the battery, and everything lights up like it should on the dash. Under the hood, I don't hear anything from the starter, but I do hear what I believe to be the injectors. The security light does not come on. Does anyone have any ideas? I tried the search button, but came up empty.
Thanks in advance, mikebaby |
Re: 02 GT will not start
Try checking the grounds to the car both at the block and the battery. Corrosion can do some strange things. Secondly, try a remote start switch by connecting it to the starter solenoid. If the ignition switch has gone bad then this should start the car. The only other item I can think of is to remove the starter and have it tested. It appears that some starters are faulting internally and not working correctly. Start with the grounds and go from there.
Welcome to the forum! |
