Go Back   Automotive Forums Car Chat > Ford > Expedition
Old 07-19-2005, 08:18 PM
js_318 js_318 is offline
Question 4x4 drive -
1977 expedition - the 4x4 wheel drive will not engage....the lights come on but the front wheel will not angage...any suggestions
Old 07-20-2005, 07:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: 4x4 drive -
Look at the actuator.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
The Following User Says Thank You to way2old For This Useful Post:
tinkering (03-11-2017)
Old 07-22-2005, 11:40 AM
ernie300 ernie300 is offline
Angry electrical malfunctions
1997 expedition major electrical problems. vehicle would not start changed batt/starter/alt./ computer you name it its been changed. Does anyone have any suggestions. Going broke trying to fix this and want to SELL this suv for a truck.
Old 07-22-2005, 06:44 PM
way2old's Avatar
TOKEN HILLBILLY
Re: 4x4 drive -
Hi ernie. Please start a new thread for your problem. Please inform if motor is cranking and not starting, or no cranking at all. Plus what you have done to try to cure it.
Old 12-21-2005, 01:42 PM
PR0866 PR0866 is offline
Re: 4x4 drive -
I have had this problem twice on my 98. 1st time it was a selenoid that needed repalcing this time it was a drive motor...so I am told. Waiting to hear the cost of replacement.
The Following User Says Thank You to PR0866 For This Useful Post:
tinkering (03-12-2017)
Old 03-11-2017, 10:13 PM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Re: 4x4 drive -
Where is the actuator? Is it hard to get at?
With my ohm meter, I checked the resistance of the switch positions against the values below.
Mode Switch Position Resistance Range
A4WD 3,700-4,100
4WD HIGH 1,040-1,160
4WD LOW 340-380
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
Old 03-12-2017, 09:24 AM
65comet's Avatar
65comet 65comet is offline
Re: 4x4 drive -
The actuator is on the back side of the transfer case.
The Following User Says Thank You to 65comet For This Useful Post:
Old 03-12-2017, 09:34 PM
tinkering's Avatar
In the 200 Club
Re: 4x4 drive -
Here are a couple of GREAT youtube videos that helped me a lot!. There are others there too.
My problem turned out to be the vacuum actuator; the plunger must be seized. I am going to try to loosen it all up with penetrating lube and prying it back and forth with a big screw driver. If that doesn't work I will remove it and work on it on the bench. Both diaphragms held vacuum just fine.The new ones are $250!!
https://www.youtube.com/watch?v=AWXiArMiqBw
https://www.youtube.com/watch?v=YUrvASBVZhk
1959 Dodge Mayfair
2004 BMW 330i
Old 03-12-2017, 10:34 PM
kingyugo kingyugo is offline
Re: 4x4 drive -
It's been proven that most 4×4 car poop out after awhile. How long have you had the expedition?
Old 03-13-2017, 10:58 AM
tinkering's Avatar
In the 200 Club
Re: 4x4 drive -
kingyugo,
If you were taking to me?
We have had our old beast for 1 year. It has 250,000 miles on it. The engine is still solid. I love the location of the oil filter up near the bumper. No more oil up the elbow
I fixed lots this winter: both exhaust manifolds and gaskets, rear wheel bearings and seals, differential oil and gasket, rear window wiper motor, rear door lock cylinder, running board lights, rear disc brakes, parking brake shoes and hardware, 4WD, etc..
It has been proven that everything stops working after awhile It is nice to be able to keep the vehicles on the road well after the expected junkyard day
1959 Dodge Mayfair
2004 BMW 330i
Old 03-13-2017, 12:41 PM
Re: 4x4 drive -
if you have the 77' expedition then yes.
Old 04-13-2017, 02:35 PM
tinkering's Avatar
In the 200 Club
Re: 4x4 drive -
It worked! I ran the actuator back and forth with a big screwdriver or something and lubed it up with some heavier spray than WD40. It has a new lease on life. I recommend trying this before spending the $250
1959 Dodge Mayfair
2004 BMW 330i
