Old 07-19-2005, 06:13 PM
airtight_python airtight_python is offline
Need Quick Advice
Where is the cheapest place to find a NEW fuel pump for a 2002 Chevy Silverado 4.3L V6? Everywhere I look is $300! I need it quick.
Old 07-19-2005, 06:54 PM
Silverado Brethern's Avatar
Silverado Brethern Silverado Brethern is offline
Re: Need Quick Advice
I'd say take it at $300. Mine was $350 from a local garage.
"Never under estimate the power of stupid people in large groups."
1997 K-1500 Silverado Vortec 350...125,610 and wounded
HD chassis package
Custom TRUE DUAL exhaust with cut-outs and Flowmaster 40 series mufflers
Poweraid Throttle Body Spacer
Custom Ram-air Intake with K&N FIPK GEN II
TFES Performance 3" Suspension Lift
Dual Air-Horn Kit with Compressor
Bed-Mounted 48" Hi-Lift Jack
Cobra Laser Radar Detector
285/75/R16 Cooper Discoverer STT's
1/4 Mile 10/15/05: 16.43 @ 91mph
Old 07-19-2005, 06:57 PM
It's just sooo steep man. Damn.
Old 07-19-2005, 10:30 PM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
WOW that is a good deal.....i used to work at NAPA and my cost wasnt even that low...
'99 Silverado 4 x 4
bunch of goodies
Old 07-19-2005, 10:55 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Now, wait guys... he said that's the fuel pump for the v6. Does that make a difference?
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-19-2005, 10:58 PM
http://www.partsamerica.com/ProductD...ype=52&ptset=A
$295 at advance
Old 07-20-2005, 02:15 AM
Appreciate it guys.. I'm gonna be skippin class and makin a trip to pick it up tomorrow.
Old 07-20-2005, 02:26 AM
korndogg's Avatar
korndogg korndogg is offline
Send a message via AIM to korndogg Send a message via MSN to korndogg Send a message via Yahoo to korndogg
can check out GMpartsdirect. same parts as the dealers except half the price. literally...half the price..lol
probably wouldnt get to you as quick as you need it though.
1968 Camaro 327
1999 Silverado 1500 Z71 LT
{o,o}
|)__)
O RLY?
http://www.cardomain.com/id/korndogg002
Old 07-20-2005, 08:48 PM
Picked up the pump this morning, $320 from Advanced .... took about 1 1/2 hour to install it. No more whine and no more cutting out above 65!
Old 07-20-2005, 08:58 PM
Re: Re: Need Quick Advice
Did you pull your bed or drop your tank? Whichever way you did it, how did you do it?
Old 07-20-2005, 10:36 PM
We chose to drop my tank since it only had about 3 gallons in it anyway. The inside of the tank was clean by the way, I thought it might have been a gunk problem but it wasn't.
You first need to disconnect the filler neck from behind the gas door. I believe there are 3, 9/32" bolts. This is to avoid breaking it when you lower the tank.
Crawl under the truck and check toward the front of the tank and disconnect the little quick connects for the fuel lines. There was also this box that we removed in front of the tank... don't know what that was but it had one 1/2" bolt and some "sliding clips" on it and it had to be moved to access the fuel line snaps.
You'll probably need a friend to help you set the tank down and get it back up there... a jack and a board may come in handy too.
There are two straps, each with one 15mm bolt in them. You'll need a pretty good lenth extension to get to the bolts. It may be easier to undo the strap toward the front of the truck first. Set that side of the tank down some and disconnect the 2 wire connections that are on the pump.
Remove the pipe clamp from around the filler neck with a 1/4" socket. Pull the filler neck off the tank and just stuff it up in there somewhere out of your way. It has a ground and some kind of vent hose on it for like the rear end?
Undo the strap toward the rear. Those straps only "hang" on, on one side, they need some twisting to come off and get out of the way.
The tank was too tall to get out from under my stock height 2x4 so you'll have to jack up the rear some to slide the tank out.
When the tank comes out it will have the "ends" of those 3 fuel lines you disconnected on it, unclip those. Clean the top of the tank to avoid dropping dirt in it. The pump is held in with a ring type thing that just needs turned a little and the pump pops right out. Use a block of wood (to avoid sparks) and hammer to turn it.
Reinstallation is opposite of the removal. Your new pump should also come with the rubber gasket and don't forget to seat that on the pump before you install the pump assembly into the tank.
Took two of us about 1 1/2 hours and we've never done it before.
