Go Back   Automotive Forums .com Car Chat > Jeep > Cherokee
Old 07-19-2005, 05:04 PM   #1
tgrudzin
Shock removal and air hammer
97 Jeep Cherokee. The rear shocks need replacing... the shocks are fine, the bushing have worn out. Not really familiar with working with air tools. If I need to use a universal socket to get to a bolt, is that an issue? Do I have to have straight access only when using an impact gun?
Ted
tgrudzin is offline   Reply With Quote
Old 07-20-2005, 12:20 PM   #2
Dale Aeppli
Re: Shock removal and air hammer
Ted
if you use a air impact wrench be cafeful and use it in bursts. these studs are know to bust off. you should try to soak the studs before trying to remove. i have a sheet on removing them if you break them off. holler can't send thru forum. [email protected] Dale
Dale Aeppli is offline   Reply With Quote
Old 09-14-2005, 04:57 PM   #3
tgrudzin
Re: Re: Shock removal and air hammer
Originally Posted by Dale Aeppli
if you use a air impact wrench be cafeful and use it in bursts. these studs are know to bust off. you should try to soak the studs before trying to remove. i have a sheet on removing them if you break them off. [email protected] Dale
Thanks, Dale, all four busted off, the 1st with an impact wrench, the second under my over-powering strength . The other two I forced off, as I already had done most of the work of cutting through the rear bed as recommended in your email. The right tools and it goes rather quickly.
Now, what about the front shocks? As those bolts also prone to breaking off or are the front easy to remove and replace?
ted
Old 09-14-2005, 06:40 PM   #4
Dale Aeppli
Re: Re: Re: Shock removal and air hammer
ted
just use a lot of blaster spray on bolts fairly easy compared to back questions holler [email protected] Dale
