Old 07-19-2005, 04:43 PM
mitachoo mitachoo is offline
Special Tool Needed for '95 Taurus Drum Brakes??
I am about to change my drum brakes on my Taurus and have been told a "special tool" (other than a standard hooked prybar thingie) is required; can anyone confirm this and suggest where I can get one?
Also, how do you know which direction to turn the tensioner inside the drum with whatever tool you end up using? Is there a "rule of thumb"?
Old 07-20-2005, 07:08 AM
mwt mwt is offline
Re: Special Tool Needed for '95 Taurus Drum Brakes??
You need the hooked prybar thingie
You need the tool that compresses the shoe spring and turn it 90 degrees
a screwdriver will do the adjusters
I can never remember which way to turn the but the drum will get looser or tighter so just play with it
That's all you need.
Mike
Old 07-20-2005, 11:03 PM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
u can use a pair of angled pliers to get the shoe hold down spring, as long as ur not replacing all the hardware...as to the adjuster...pushing it down will loosen it...up will tighten it...no special tool...just normal brake drum tools...u might want to replace ur wheel cylinders....bet their frozen by now
Old 09-19-2005, 11:19 AM
Re: Re: Special Tool Needed for '95 Taurus Drum Brakes??
Was not nearly as bad as I expected. One of the cylinders was in fact frozen so I went ahead and replaced both.
