Go Back   Automotive Forums Car Chat > Cars in General > Exterior | Bodykits | Lighting | Aerodynamics
Exterior | Bodykits | Lighting | Aerodynamics Discuss different body kits, body work in general, and all types of exterior modifications.
Old 07-19-2005, 04:33 PM
88irocZ 88irocZ is offline
clear coat
as yall know GM had a big problem in the 80's with the clear coat peeling up. well my iroc has this problem. there is a fairly good spot on the hood and one on the back spoiler. i was wondering if there is a way of fixing this without getting a new paint job. can i just use a rattle can clear coat? what would you guys recomend?
Old 07-19-2005, 04:37 PM
TOMMY81 TOMMY81 is offline
Re: clear coat
Originally Posted by 88irocZ
as yall GM had a big problem in the 80's with the clear coat peeling up. well my iroc has this problem. there is a fairly good spot on the hood and one on the back spoiler. i was wondering if there is a way of fixing this without getting a new paint job. can i just use a rattle can clear coat? what would you guys recomend?
I used a clear coat can and it worked great! I had to use three cans per section
Old 07-19-2005, 09:36 PM
astroracer's Avatar
astroracer astroracer is offline
You can spray as much clear "over" the bad paint as you want but, that is not going to "fix" the bad paint where it hasn't lifted. The old paint will still have an adhesion problem and it will continue to lift even under the new paint. The only way to fix the problem is to remove the old paint and respray...
Mark
Old 07-19-2005, 11:43 PM
well i would just like a temporary fix. if it keeps peeling up its not a problem i will just shoot more clear. would it be better if i used some of the touch up spray paint stuff. i will probably be getting the car painted in the next year or so...
Old 07-20-2005, 05:55 AM
astroracer's Avatar
I wouldn't worry about it, leave it alone. All you will be doing is creating more work for the paint shop. Especially if they have to sand off all of your repaired areas. I know I would charge more to do this... It has to come off to prevent paint incompatability problems.
If you really need to do some touchup work I would suggest you take the car to a good paint shop and have them look at it. Ask them what they would use to do it with the thought in mind of a complete repaint in a year or so...
Mark
