Old 07-19-2005, 02:28 PM
CIDDAN1 CIDDAN1 is offline
IGNITION PROBLEM-'90 lumina APV 3.1L
I stoped the engine, OK. next day there is no gas throught injectors and the engine don't start.
The pomp starts and then stops like usualy on start, it is 12Vcc on hot wire of injectors, but i don't have any signal on the others.
I believe thats is a bad ground somewhere but i don't know where to look after. Please help me! Thanks
Old 07-19-2005, 08:21 PM
ACEMAN8822 ACEMAN8822 is offline
I am working on 90 LUMINA Euro 3.1 too. Do you have a spark? If you check for spark make sure you use a spark tester so you dont damage ignition control module. If icm is bad or if crank sensor is bad you wont get a signal that lets the injectors know when to fire. Did you check fuses under the hood at the front passenger side of car? I have heard that connections under that relay center get corroded sometimes too because of their location. SUPPORT OUR TROOPS. P.S. I HAVE A GM SERVICE MANUAL IF YOU NEED ANY MORE INFO. [email protected]
Old 07-20-2005, 03:35 PM
Re: IGNITION PROBLEM-'90 lumina APV 3.1L
Thank you ACEMAN8822!
I fixed the problem. there were corroded conectors on icm.
