Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-19-2005, 01:54 PM
Sean Price Sean Price is offline
Send a message via AIM to Sean Price Send a message via Yahoo to Sean Price
quick question regarding the lift points on civics..
its been botherin me for some time now..
on the manual regardin the side lift poins on a 2000 civic sdn my question is this..
is the lift piont the actual arrow? i.e. do you put the jack right underneathe that sed arrow? or the metal piece juttin out that the arrow is point at?
also if your goint to be using jacks? where do you place those on?
i'm jus tryin to keep this safe...
thanks fella's..
oNe
Sean Price
keepin it real/packin steeL/gettin high/cuz life's a b*tch and then u die....
Old 07-19-2005, 11:11 PM
siege911's Avatar
siege911 siege911 is offline
Send a message via AIM to siege911
Re: quick question regarding the lift points on civics..
Okay, on the sides there should be two pieces of metal (one on each side) sticking out, about 2 inches long and half an inch to an inch deep, that's where the jack stands go... and to jack it up, use the jack point at either the front or the back, depending on which end you need to work on. The points in the front and back are fairly easy to spot, so it shouldn't be too hard.
www.civicland.com
www.turbod16.com
Originally Posted by Ace$nyper
The Popes really a vampire in a pyramid scheme to bring Attila the hun back from the dead.
You all are fucktards and would bow to the ls1 and my 54 foot long ninja sword.
Old 07-20-2005, 07:38 AM
Re: Re: quick question regarding the lift points on civics..
thanks for the info main...
so to recap if i want to do an oil change i would locate the CENTER jack point on the front of the car....raise that up and then place the jack stands by the arrows DIRECTLy underneathe the metal parts that stick out...
cooL i got it now...
oNe
p.s. the frong center jack point will be labled right? when i'm under there what do i look for?
Sean Price
Old 07-20-2005, 10:09 PM
siege911's Avatar
it looks like a metal rod that's bent in a u-shape under the front bumper... it stands out pretty well, right in the middle, more towards the driver's side.
www.civicland.com
www.turbod16.com
