Old 07-19-2005, 01:23 PM
The7thRelic The7thRelic is offline
Question 1991 Eagle Talon TSI
OK I have a question for you guys...Im looking to buy this Talon its the TSI FWD, the guy wants 500$ for it and its in great shape just 1 problem....it doesnt start...the guy replaced the timing belt, changed out the head, bearings, rods, headgasket, pistons the works...also changed out ignation coil, plugs and wires....it ran perfet then he parked it and now it wont start. It cranks but gets no spark to the plugs...what do u think could be the problem? Abvoisily its an electrical issue but what could it be?
Old 07-19-2005, 01:47 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
For $500 I would say buy it, as long as he has all the receipts for the work done to it, or can prove some other way that the work was done, and decent quality parts were used. Then afterward you can figure out what is wrong with it, but for $500, it's worth a shot.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-19-2005, 03:20 PM
I realize its worth buying the car for 500$ even if i was just to part it out but i dont understand why it would run perfect all day then over nite it wouldnt create a spark to the plugs
Old 07-19-2005, 03:28 PM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: 1991 Eagle Talon TSI
Leaking caps on the ECU board?
Mouse chewed through the wiring?
Bad CAS?
Who knows....It could be 100 different things
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-19-2005, 03:43 PM
Ive been lookin around and i hear alot of issues with the ECU and fuse im not sure what an CAS is? (sorry a lil retarded about cars somtimes)
Old 07-19-2005, 04:56 PM
EDMUND65's Avatar
EDMUND65 EDMUND65 is offline
Send a message via AIM to EDMUND65
dont hesitate! i'd buy it in a heart beat!!! partit out prolly make a good dollar, if not a really nice car to drive after you fix... just my opinion
