Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-19-2005, 08:26 AM
greennike's Avatar
greennike greennike is offline
Exclamation Electrical Problems
Fun Day. On my way to work this morning:
1.) Engine Light Came On (Did not yet check code, will tonight)
2.) Battery Light Came On
3.) ABS/Brake Light Came On
4.) Air Bag Light Came On
5.) Gauge Cluster went completely dead (Tach, Spedometer, etc.)
This did not happen all at once, but in series. I was going 75 and it did not affect driving/acceleration, etc. After about 30 seconds, everything went back to normal with the exception of the airbag light.
Is my puter melting? Any suggestions (I will update after i get code)
Old 07-20-2005, 08:11 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Sounds like an alternator
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-26-2005, 10:33 AM
greennike's Avatar
Angry Update - Electrical
OK,
Replaced the alternator...Some problems remain, others are new:
1.) Check Engine light still on - engine code is for glow plug sensor...
2.) Air Bag Light Still on
3.) NEW - Headlights do not work. Bright signal is stuck on and lights do not work (Blinkers work fine in headlight assembly)
4.) NEW - Was rollling the passanger window down and it started going up and down on it's own. Althought it works just fine now.
Any suggestions on what to check. Is this a dealer question or would I be better taking it to a regular mechanic.
Oh yeah, anyone wanna buy a jetta...
Old 07-26-2005, 12:46 PM
98R/TDailyDriver's Avatar
98R/TDailyDriver 98R/TDailyDriver is offline
Send a message via AIM to 98R/TDailyDriver Send a message via MSN to 98R/TDailyDriver Send a message via Yahoo to 98R/TDailyDriver
Re: Electrical Problems
Don't take it to a mechanic -things will just get worse.
Take it to VW -its probably something little...
Old 07-27-2005, 07:33 PM
VDUBMAN
Sounds like your comfort control module is bad. Normally when alot of things go bad in the inside of the car (windows, lights, radio ect.) its the comfort module thats bad.
But it also seems like your instrument cluster is faulty due to all those lights being on and then your cluster just dying. THe codes need to be read out to be sure, but instrument cluster is something you cant replace yourself because you need to program your keys to the new cluster and thats something only a dealer can do.
