My car starts then shuts off after like 30 seconds
Hi guys I am 16 and just boght a Camaro...nothing special just a 1994 3.4 liter V6 Automatic.....I have had it for 2 months.....This morning I woke up and my car would not start so I got my dads cables and jumped my car...as I was pulling out of the driveway 30 seconds later it just shut off......So I rolled it back and jumped it again and let it sit there idle for about 10 minutes and it shut off again....One thing I have noticed is my car alarm does not work properly...once I armed the car inside and like 2 minutes later I heard zzzzz.zz.zzzzzz.zzzzzzzzzzz noises coming from near my security alarm light...I'm not sure if the alarm is taking too much juice from the battery.....I have jumped it 3 times before that...I'm not sure what it is It can't be the battery right because it starts I thought it might be the alternator can your car shut off like that if your alternator is not working properly...any help from people who know waaayyyy more than me I would apprecite it
Re: My car starts then shuts off after like 30 seconds
could be a alternator problem. Sounds like an alternator problem...
if you take out the alternator and then go to autozone or a parts store they can test it for free.
they can also test your battery. |
Re: Re: My car starts then shuts off after like 30 seconds
Well there is a way you could test it yourself with a voltometer or whatever but im not really sure how, taking it to Autozone is the best bet.
Dont buy new one-just rebuild it-threses a kit for that real cheap that includes brushes diodes and bearings (if the alternator isnt burnt though). Takes 20 min to rebuild. Do u have the voltmeter gage in your claster?
By the way it sounds more like your fuel pump problem or spark and the injection as well |
Ofcourse the fuel pump might be a problem along with spark but if that was the problem then his car wouldnt turn over, his car just cant stay alive and thats what an alternator does but to be sure, gotta test it out! that and cables too might be a problem.
Test man! TEST! Seriously it saves money, so do it.
If it did, you'd hook up your voltmeter (never rely on the stock gauge) and with load, headlights, heater fan, wipers, you should be alteast 13.5. Anything directly at 13 or below I wouldn't trust. |
true...
If the battery has a full charge and the car shuts off shortly after starting...it isn't the alternator.
Unless the battery isnt at full charge or is not holding a charge and the alternator dwindled and stopped charging the battery and him starting the engine and cranking it over a couple times.....that would drain the battery enough to where it wouldnt stay running.
OR it isnt the battery or alternator and he has a fuel problem.....maybe......but he has to charge the battery each time he has to start it so that would say battery.
