Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 07-19-2005, 02:10 AM
Glina Glina is offline
Question '91 throttle body issue
There are few problems - I suppose that they are connected.
Toyota, 3VZE engine, runs very well but:
1. When I drive it for about 10 mins. at 3000rpm at normal operating temperature and I stop the idle speed is very low and rough 400-500 rpm, then I depress accelerator for a while and idle gets normal 850-900 rpm???
2. When I start the engine in the morning when it's cold it starts very well, but I think the high idle stays too long - it's summer so it should not be cold for that long (around 10 minuts of operating)- thermostat is new.
3. The last thing is that when I drive to job (around 1,5 mile) and I stop the idle is still around 1300 rpm. After work ca. 8 hours it's hard to start, but in the morning and when it's hot starts perfectly.
Any ideas?
Thanks for help.
Old 07-19-2005, 11:25 AM
and one more question - where is situated idle speed control valve? Couldn't find in service manual and EPC
Old 07-22-2005, 02:14 AM
Exclamation
Anyone! H.E.L.P!
Old 07-22-2005, 08:43 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: '91 throttle body issue
The air valve is what performs this function in your engine. Clean throttle body and EGR valve.
http://www.4x4wire.com/toyota/mainte...throttle_body/
http://personal.utulsa.edu/~nathan-b...81descript.pdf
http://personal.utulsa.edu/~nathan-b...82operatio.pdf
http://personal.utulsa.edu/~nathan-b...93throttle.pdf
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-25-2005, 01:29 AM
How do I clean EGR?
Old 07-25-2005, 09:31 AM
Brian R.'s Avatar
Resident Chemist
Remove it from the engine and use carburetor cleaner and whatever brushed or tools are necessary.
Old 08-03-2005, 03:26 AM
The problem is solved!
Vacuum lines from Throttle body to EGR were connected wrongly.
