Old 07-18-2005, 11:44 PM
cdawg001 cdawg001 is offline
1200.1 question
I am thinking about buying a 1200.1 amp and I want to hook it up to 2 15s. Will the amp push 1200 to each amp or 600?
Old 07-19-2005, 07:17 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Re: 1200.1 question
600 to each
Old 07-19-2005, 10:27 PM
RSLaser RSLaser is offline
the amp will push 600 to each SUB lol
but in all seriousness, if its 2 channel, than you should be able to bridge it and get the 1200 to both subs.
1991 Plymouth Laser RS
Only sat for a few years....
Old 07-20-2005, 08:22 AM
Re: 1200.1 question
it would end up being about the same... right?
Old 07-20-2005, 12:03 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
ummmm ....... the .1 means a 1 channel. It just has 2 parralelled outputs for wiring convenience
Old 07-20-2005, 10:29 PM
so then if he hooked up both then the power would be split? I wasnt sure if it was a single or dual channel, thats why im asking.
Old 07-21-2005, 12:00 PM
Audio Guy
it's a single channel amp, if he connects 2 speakers - each speaker will receive 1/2 of thetotal power (assuming both speakers are the same impedance)
Old 07-21-2005, 09:50 PM
Thanks for clearin that up.
Old 07-23-2005, 12:05 AM
Jeremy86 Jeremy86 is offline
Send a message via AIM to Jeremy86
Re: 1200.1 question
x2 about what paul said. Same subs should get 600 to each sub.
Aka 93 Cutty
Working on my next project: A 1986 Honda CRX. Little beater with lots of engine
Car Audio Freak
http://www.sounddomain.com/ride/613185
Old 07-25-2005, 02:06 AM
Could you tell me if this is a good setup and how much would be on each sub?
http://www.crutchfield.com/S-3UFwNPL...50&I=700TOTALN
Old 07-25-2005, 12:14 PM
Audio Guy
audiobahn is notthwat good ... except maybe for volume. That amp/speaker combo is DUMB once you read the specs. It's a 4 ch amp, it's rated at 500 Watts/ch AT 4OHMS ONLY ..... the subs are dual 4 ohm, if you wire the coils in parallel you will be below the impedance when the amp is bridged - if you wire them in series, the amp will only put out 300 W to each sub.
Old 07-31-2005, 05:40 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: 1200.1 question
but if you have 2 d4 subs you can wire one coil to each chanel
