Go Back   Automotive Forums .com Car Chat > Chevrolet > Lumina
Old 07-19-2005, 12:29 AM   #1
damoncoker
Send a message via Yahoo to damoncoker
Question 1990 lumina stalls only when it's hot outside
i have this 1990 lumina and it runs just great in cooler weather, but let it get above 80 degrees outside and the check engine soon light comes on and it stalls everytime i take my foot off the pedal... i have no clue how to fix it other then move some place where it stays cooler outside year round?
damoncoker is offline   Reply With Quote
Old 07-19-2005, 08:51 AM   #2
jeffcoslacker
Lactose the Intolerant
jeffcoslacker's Avatar
Re: 1990 lumina stalls only when it's hot outside
Which engine?
It would seem that the idle mixture is too lean to have a stable idle at higher ambient temps, so I'd be leaning towards at intake air temp sensor (not sure if that year had that, though), MAP sensor, or possibly the vacuum hose going to the MAP.
A sticking EGR valve can cause that, but I don't see where it would coincide with outside temp.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
jeffcoslacker is offline   Reply With Quote
Old 07-19-2005, 05:05 PM   #3
damoncoker
Re: Re: 1990 lumina stalls only when it's hot outside
Originally Posted by jeffcoslacker
Which engine?
my car has the 3.1 V-6, i'll take a look at the vacum hose on that map sensor, if i can locate it... not really sure what i'm looking for though, i'm guessing it would be located on or near the air intake? it's really odd it only does it when it gets above 80 degrees and the weather has been warmer this past week, so the stalling is driving me crazy... thanks for taking the time out to try and help me...
Old 07-19-2005, 10:07 PM   #4
ACEMAN8822
My 90 lumina does have intake air temp. sensor. P lugs in near front before air filter.Hard to check the map sensor vacuum hoses way back behind engine.The hard plastic hoses suck.
ACEMAN8822 is offline   Reply With Quote
Old 07-28-2005, 07:21 PM   #5
XGamesJ6
XGamesJ6's Avatar
you said the check engine light comes on, do a code check by taking a paper clip and hooking it all up the link is http://jeffex.info/GMcodes.htm there are other links though, thats just mine, now it blinks each code 3 times, first a 12 which is normal, then another code. which is the problem code.
2009 Pontiac G6 2.4L L4
2007 Buick Lucerne CXL 3.8L V6
2007 Chevrolet TrailBlazer LT 4.2L L6
1993 Oldsmobile Cutlass Supreme SL 3.1L V6
XGamesJ6 is offline   Reply With Quote
