Old 07-18-2005, 11:23 PM
gforceman123 gforceman123 is offline
Question 99 taurus lock problem ( gem mod ) ?
when i use the door lock button or the key fob to open ALL doors . the locks " try "to open seems like not enough power to unlock or lock doors maybe the gem module i am gettting 12 volts to the lock motor but why does it affect all locks ? or any suggestions i can try ty
Old 07-20-2005, 11:35 PM
bump
Old 07-24-2005, 10:08 PM
any suggestions ? thanks
Old 07-30-2005, 11:15 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 99 taurus lock problem ( gem mod ) ?
What does the 12 volts at the lock motor do when you attempt to lock and unlock the doors? You may need an analog multimeter or highspeed DMM to see the change in voltage. Or, if your meter has a min-max feature, you might try using that. If the voltage drops considerably, you might have a bad ground wire somewhere for the lock system, or you might have a corroded or damaged wire in the lock system. First place I would start looking is the multi-wire connection near the driver's door hinge. Those connections have been a problem in the past.
-Rod
