Old 07-19-2005, 12:10 AM
Rs051802 Rs051802 is offline
Question 95 chevy hardly starts
Hey guys, i have problems. I have a 95 chevy truck with a fresh vortec 4.3. It won't start. It will start and run as far as I can go so long as i do not kill it. If I kill it, the fuel pump will not turn back on for like 12 hours. Sometimes when i stop cranking the engine i hear the fuel pump then. I have put in new oil pressure switch, 4 fuel pumps (only bought one, warranty handled others), and fuel pump relay. Only thing i have not done this time is change the filter. This happened once before and that time i went through 3 fuel pumps before i got it to work. that was 4 months ago. I have checked my lines, they seem fine, no kinks or leaks. Could one of them have collapsed and be causing the fuel pump not pressurize???????? Please help me i need the transportation!!
Old 07-21-2005, 03:48 PM
kenny-1907's Avatar
kenny-1907 kenny-1907 is offline
Send a message via MSN to kenny-1907
Re: 95 chevy hardly starts
Were the fuel pumps that were taken back tested to see if they were still working or did they just give you new ones. If they were not tested , i would take out the ignition module and have that tested.
**2007 Avalanche LT. **
6" Pro Comp lift
305/55/20 BFG A/T KO'S
K&N FIPK GENII
Flo Pro V force muffler & 4" slash cut stainless tips
Color matched front and rear Bowties
3" polished stainless bull bar and Nerf bars
Old 07-21-2005, 04:29 PM
tom3 tom3 is offline
There is a plug in connector in the top inside of the gas tank that will corrode and burn over time, really a head scratcher when it's the problem. Sounds like you've tried all else anyway.
Old 07-22-2005, 06:04 PM
Thanks alot, yes they were tested, they all were bad. turns out, the little wire plug in the top of the sending unit had went bad, and went it did over time it caused my ecm to go out. put in a new sending unit, tried it, no start. new ecm cranked right up thanks alot guys
