Old 07-18-2005, 10:48 PM
atkinsj atkinsj is offline
cuts out @ full throttle
ok, so my problem is i have a 94 Geo Metro, runs pretty decently until you shift and push the gas further than about half way. The car begins to spuuter like it is going to cut out, I let out the gas pedal and all is well, I slowly try to push it back further and it starts to cut out again. A few times I pushed the gas further than halfway and it started to go, but then my car violently sputtered and cut out. I'm thinking that there is something majorly wrong ... I'm also not good with diagnosing problems, ANY help would be awesome.
Old 07-19-2005, 09:09 AM
geozukigti geozukigti is offline
sounds like a bad TPS to me. Or a mis-aligned one. Does it cut out under load too? or just under heavy throttle.
Old 07-19-2005, 01:39 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: cuts out @ full throttle
one of mine did same thing and turned out to be bad fuel pump, pressure was right but no volume
Old 07-20-2005, 12:32 AM
well sometimes it cuts out under heavy throttle no matter what sort of load there is ... most of the time it is just me, and it doesnt matter if its going down hill or up ... sometimes it really gets up and goes, sometimes it stutters, sometimes it stutters violently, but keeps running. I was thinking it probably has something to do with fuel delivery.
Old 07-20-2005, 11:57 PM
hodunwun hodunwun is offline
If you haven't done so recently, replace the fuel filter by the tank.
dv
