Old 07-18-2005, 10:47 PM
Xx_Eclipsekid_xX Xx_Eclipsekid_xX is offline
Send a message via AIM to Xx_Eclipsekid_xX Send a message via Yahoo to Xx_Eclipsekid_xX
Question Balance shaft...Purpose?
Hey hows it goin tonight, hopefully when reading this you have an idea of what im talkin about...I have seen people with "balance shaft removal kits" and confused i looked at the kits discription...and all i got from that is it removes the balance shaft..adding horses...So what first off...what is the balance shaft exactly...and why would they put it into the car if, since it can be removed, it is not fully needed...and rids the car of its precious horses...Hope you can help me out with my Q's..and thanx for readin and thanx even more if yah can response...
*~~*Ryan*~~*
Old 07-18-2005, 10:57 PM
tfoti tfoti is offline
Testiklees
Send a message via AIM to tfoti Send a message via MSN to tfoti
Re: Balance shaft...Purpose?
Basically it decreases engine vibration, for the purpose of a more comfortable ride. If you are in to performance removing these will allow the motor to rev a little bit quicker since the crank doesn't have to turn the shafts.
Removing them also has the added protection of the balance shaft belt breaking and wrapping itself up in the timing belt.
If removed you might notice a more pronounced vibration at certain RPM's, some have reported no change.
For a more detailed explanation, check this out
http://www.vfaq.com/mods/balance-shafts.html
Tim
1990 Talon AWD
2.3 stroker, 8.8 wiseco, FIC 750's, DSMLink,
PTE SCM5031
Old 07-20-2005, 02:43 AM
kjewer1 kjewer1 is offline
AF - Advisor
I just want to add that this mod does not add HP. IT may free up a few hp, but nothing that you will notice. Its more for more oil pressure at idle and eliminating the liability mentioned above with the belt letting go. The shaft also spins at twice the motors RPM, so it can be going as fast as 15000 rpm with a stock rev limiter. Its not uncommon for the bearing to sieze and spin ruining your day..
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-20-2005, 05:39 PM
--- --- is offline
Re: Re: Balance shaft...Purpose?
[quote=95 GSXracer Its not uncommon for the bearing to sieze and spin ruining your day..[/QUOTE]
Oh it'd ruin a lot more than your day, lol.
I drive a slow car.
