Old 07-18-2005, 10:07 PM
souphmars souphmars is offline
won't start sometimes
itonly does it ever now and then- it tries to start, it cranks but it never starts- it will get drove, then it will get turned off like at a store or something- he will go inside, come back out to leave and it won't start- its weird- it runs like nothing is wrong, and it is inconsistent- it is almost like something has to cool off or something, but it never shuts off or anything while he is driving- this is my dad's- has anyone ever had this problem or something similiar- he has replaced many parts- it is a 1990, with a ton of miles
Old 07-18-2005, 10:24 PM
ctesla's Avatar
ctesla ctesla is offline
is this a 4.0l (straight six)?
manual or auto?
have heard of a "heat sensor" behind engine near bell housing for transmission...
I can fax or email a schematic
chris
[email protected]
ASE cert.instructor
Old 07-18-2005, 10:37 PM
ctesla's Avatar
Re: won't start sometimes
manual or auto?
chris
[email protected]
ASE cert.instructor
...sorry...
meant to say "crank sensor" acting up from heat behind the engine...
but, you should look into other posts in this forum, as it appears you are not alone...
cracked coils, throttle positioning sensor, could also be a failing electronic control module, etc.
heat does play a harsh role under the hood..
hope this helps.
Old 07-19-2005, 01:12 AM
simoncs simoncs is offline
Re: Re: won't start sometimes
...sorry...
hope this helps.
Hi
I had same problem- sometimes starts sometimes not - turned out to be the inhibitor sensor was not working properly.
This prevents the car starting in gear.
all you need to do is wiggle the transmission/gear stick back and forward (while it is in Park) while turning the key.
Old 07-19-2005, 04:33 AM
89ltd 89ltd is offline
also known as the nss switch, but if it was faulty, the engine would not crank at all. I would say it is the crank sensor or pickup coil in the distributor, get yourself a spark tester and check for spark when it won't start, go from there.
Old 07-19-2005, 06:46 PM
it is an auto inline 6
Old 07-19-2005, 07:11 PM
he just replaced the pickup coil- he is looking to see what the crank sensor is
Old 07-19-2005, 07:16 PM
is it a crankshaft position sensor???where is it exactly located- i need to know the exact location, so i can explain it to him
Old 07-20-2005, 11:12 AM
Dale Aeppli Dale Aeppli is offline
http://www.autozone.com/images/cds/g...3d80152484.gif
the crankshaft sensor is located on the drivers side , on the bellhousing , right above the front driveshaft. Check this site hope it helps Dale [email protected]
Old 07-20-2005, 08:40 PM
thanks will try replacing and will give u an update later-i tried searching for the same problem in other posts and could not find it
Old 07-20-2005, 09:44 PM
Questions just holler [email protected]
Old 07-29-2005, 09:48 AM
widglid96 widglid96 is offline
HAVE YOU FOUND THE PROBLEM YET?
i HAVE THE SAME THING GOING ON WITH MY 1990,
HAVE PUT IN A NEW DISTRIBUTOR,COIL,ECM,CRANKSENSOR AND STILL KEEPS DOING IT,
Old 08-02-2005, 02:10 PM
FlatLanderHandicap FlatLanderHandicap is offline
I have the same problem with a 92 laredo 4.0L. It will start fine and then 5 min later when i get out of the store it doesnt start. I'm gonna check out the TPS b/c I also have issues with shifting from 2nd to 3rd. Hopefully 2 birds with 1 stone eh!
Old 08-05-2005, 03:16 PM
Well I Replaced The Starter Relay, And Havent Had Any Problems Since, It May Have Been That Or Just Cleaning The Connections While Replacing That Did The Trick.
Old 08-08-2005, 06:49 PM
I cleaned the throttle body and checked the connections on the TPS, my shifting problem is fixed but the sometimes not starting problem is still there. Whats the starter relay? where is it? how much did it cost you?
