Go Back   Automotive Forums Car Chat > Honda > Interior | Audio | Security
Interior | Audio | Security Tech forum to assist in Honda/Acura Interior, Audio and Security.
Old 07-18-2005, 10:21 PM
The_Fast_One The_Fast_One is offline
Exclamation my cd player I NEED HELP!
HI,
I HAVE A PANASONIC CQ_DFX683U AND I CONNECTED EVERYTHING AND IT DIDNT WORK I KNOW THE FUSE IN IT IS GOOD AND THE ONLY THING THAT I FOUND OUT WAS THAT I CONNECTED EVERYTHING BUT THE ANTENNA AND I REMEMBER THAT IT SAID SOMETHING ABOUT THE ANTENNA MUST BE CONNECTED TO RECIEVE SATILLITE CONNECTION I GUESS THAT MEANS TO POWER IT ON??? THE CD PLAYER DOESNT HAVE ANY STICKER ON IT SAYING WHAT WIRES TO CONNECT SO I GOT THE INFO FROM HERE FROM I THINK HIS NAME WAS ''CIVICSPOON'' FROM ANOTHER THREAD STARTED FROM SOME 1 ELSE AND USED IT AND HAD NO LUCK.ALSO I KNOW THAT THE CD PLAYER WORKS BECAUSE I CHECKED IT AND I POWERED ON USING THE BATTERY,,SO,, CAN SOME 1 HELP ME I WANNA CONNECT IT I JUST GOT IT AND I NEED HELP. HERES THE INFO I USED ON CONNECTING THE CD PLAYER--
--Front Left Speaker
White - Blue/Green +
White/Black - Gray/Black -
Front Right Speaker
Gray - Red/Green +
Gray/Black - Brown/Black -
Rear Left Speaker
Green - Blue/Yellow +
Green/Black - Gray/White -
Rear Right Speaker
Purple - Red/Yellow +
Purple/Black - Brown/White -
Constant Power
Yellow - White/Blue
Ignition On
Red - Yellow/Red
Ground
Black
Other
Red/Black - Dimmer
________________________________
Not Positive on these wires...
CD Player Side:
Blue = Power Antenna
Blue/White = System Remote Control
Brown/White = Dimmer???
the-fast-one.
Old 07-26-2005, 01:17 PM
smm1099 smm1099 is offline
Send a message via AIM to smm1099 Send a message via Yahoo to smm1099
Re: my cd player I NEED HELP!
get best buy or a local company to do it they should only charge a bout 40-50 bucks if they do it and itll save you a lot of trouble, i tried my self and the same thing happened and all my wires were in. i took it to best buy and they had it in and aworkin in about 20 minutes. they said i blew fuses and thats it, pissed me off that i didnt check those
94 Honda Civic DX
Audio:
2 10" Rockfords "Punch", Pioneer 2600 deck, Rockford Fosgate 600w amp
Engine:
1.5L SOHC
Exterior:
17" Anthracite Enkei or52 w/ Kumho tires
Check it out:
www.cardomain.com/ride/819726
Old 07-26-2005, 01:59 PM
94hondaacc 94hondaacc is offline
First you need to get a test light, and check for power. in both the yellow and red wire. also check the ground. if there is no power in the yellow the fuse should be under your hood,and if no power in the red the fuse should be in the drivers side somewhere underneath there. the the ant wire doesnt need to be connectted for the radio to work,the radio should still power on.please put black tape on everywire after you connect it, the simpilist contact and the fuse is going to blow or worse the radio. the dimmer doesnt have to be connected cause that radio lights up all the time. the blue/white is for a power amp remote wire. try this website www.installdr.com hope this helps
Old 07-27-2005, 06:39 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
If you have a reset button try hitting that a couple of times.
