Old 07-18-2005, 09:07 PM
94VL 94VL is offline
Wobble Wobble Wobble
1994 VL manual trans,for years now it has had an annoying wobble.Everything has been looked at/replaced and it still does it.You can feel it very faintly at 30mph,but hit 60mph and its pretty strong.The center console will vibrate from side to side.The tie rod ends have been replaced,alignment done a couple times,moved the front tires to the rear and new tires mounted out back,new CV shaft,new pads/rotors,engine torque strut,sway bar links....you name it.I'm left wondering...wheel hubs? Control arm bushings? There isnt a lot left.It also pulls slightly to the right,even though the steering wheel is dead-on center when driving straight-away.This car has never been in an accident,never jumped a curb,and the wheels are identically located in the wheelwells both sides.
One final note,after a high speed 8 mile drive,neither tire is excessively hot....so there is no gross misalignment of toe in/toe out.
Old 07-18-2005, 09:30 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: Wobble Wobble Wobble
hmmm..... you've replaced everything i would suggust to replace. I am kinda having the same problem right now actually. I have really bad front end vibration at 60+ MPH, but i am also lowered and occured only after that. So its possible that its a hub assembly or maybe even blown from struts. If they cannot control the spring, you'll get some nice vibrations.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 07-19-2005, 07:10 PM
The struts were among the changed items.They are solid....the front end doesnt sway or bounce whatsoever.I have just added a strut stress bar and it makes no different to the wobble either.However the car now handles like its on rails.The wobble is noticeable at 30mph...it comes and goes,but hit 60 and its really noticeable.
Old 07-19-2005, 09:56 PM
sailor262 sailor262 is offline
Re: Re: Wobble Wobble Wobble
check Tire Balance? Bent Rim? Bad Tire?
Old 07-19-2005, 09:58 PM
alphalanos alphalanos is offline
check your steering shaft and all that
96 EJ6. Future home of boosted B18C1.
Old 07-21-2005, 07:07 PM
One thing I have noticed....I lifted the drivers side off the ground,removed the wheel,and spun it in gear....the inner CV joint isnt rotating in a circular fashion,its more of an eccentric manner(and there is a click every few revolutions).Its effecting the outer joint as well,and making the hub/spindle/knuckle vibrate rapidly.I think with the added stress of the wheel/tire being mounted its amplifying the problem.The wheel/tire will wobble when spun as well.I will be replacing that shaft and then trying a test run.
Funny,as the boots are perfect (OEM) and the shaft is very tight,no play.I guess the inner joint is binding up.
Old 11-17-2005, 08:06 PM
mhartke mhartke is offline
cv shafts will usually cause a wooble condition under accelleration.
Old 11-17-2005, 08:35 PM
colinlesser colinlesser is offline
Send a message via Yahoo to colinlesser
or a bent frame
Old 11-17-2005, 08:59 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Or bent rims, have you checked them?
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 11-18-2005, 10:57 AM
Coupons420 Coupons420 is offline
mine does the same at around 60 up but only cuz i like to pull the e brake and spin around, so i have uneven tire wear...
Old 11-18-2005, 11:29 AM
yea ebarkes are even more fun in the snow
Old 11-20-2005, 11:18 AM
Chevalier Chevalier is offline
Send a message via MSN to Chevalier
RWD is better in the snow.. muhahha.. * laughs at the truck parted in driveway * says the cav sitting in the garage..
and getting back to this..
my car does the same cuz the back tires are flat spotted.. i have NO idea why *looks around*
control arm bushing may be it too i had them replaced when it did it before.
www.cardomain.com/id/94caviguy
Old 11-23-2005, 04:50 AM
Tookie Tookie is offline
I resolved the same problem by replacing my left front ball joint. Under inspection the joint appeared to be good, but close inspection indicated some excessive play. It was missed by previous inspections. There were no other indicators apparent, strangely enough.
Old 11-24-2005, 11:44 AM
The problem seemed to be mainly the left front wheel hub,(the flange was bent) and front tires.It now takes a long time to get a minor wobble,and thats well above the legal speed limit.
