Old 07-18-2005, 09:03 PM
dlstewart01 dlstewart01 is offline
Question One side of truck sits higher
I have a 2005 GMC Sierra 2 wh Dr. ext cab that sits 1 inch higher in front on the passenger side. Have you guys seen this? Is this a problem?
Thanks for your comments,
May the force be with you,
Don
Old 07-18-2005, 09:59 PM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
has the truck been in an accident? have you ran over anything? have you checked all the air pressure? are all the tired the same size? i really dont know what else unless something is bent or broke. could check your shocks and springs and bushing in the front end linkage.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 07-18-2005, 10:00 PM
walbern1 walbern1 is offline
Re: One side of truck sits higher
My 2002 sits crooked as well, I would of thought they had this fixed by now. I have read different forum articles about this but I can't remember whether there was a definite answer on a cause or solution.
2007 Murano SL AWD
2003 Grand Caravan Sport
If you're not livin on the edge you're takin up too much space!
Old 07-18-2005, 10:06 PM
3wbdriver 3wbdriver is offline
My '04 sits high on the passenger side rear. Go figure. If it gets to be too much of an eyesore, I'll make a spring spacer to level it. Since yours is in the front, you might check the sway bar links on the front end, and make sure they are adjusted even. you might even try adjusting them. It's an old racer's trick to adjust some wedge into the car. But since the truck is so new, I'd have the dealer try the adjusting. I would think it would fall under a warranty issue.
GAS IT TIL YOU SEE GOD, THEN TURN LEFT!!!!!!
Old 07-18-2005, 10:15 PM
if its under warranty go to the stealer and make them work for the money they robb us out of every time we go. if no warranty then go to like a auto body shop and see what they say.
Old 07-19-2005, 03:27 PM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Worst thing you can ever do is take a tape measure to your rig. I work for an air suspension supplier, and previously at a GMC dealer for 12 years. You'd be hard pressed to find any vehicle that sat level once you measured it.
You didn't measure from the bumper to the ground did you? Bumpers are rarely even. You should measure at the fender opening to the ground through the hub center.
One way or another, let the dealer straighten it out if you want to persue it and it is under warranty.
Old 07-19-2005, 03:43 PM
chuck16's Avatar
chuck16 chuck16 is offline
Gas tank on the Driver Side throws part of the Vehicle off balance.... I notice mine sits a little lower on the Drivers said with a full tank of gas.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 07-19-2005, 03:46 PM
Re: Re: One side of truck sits higher
It shouldn't. The factory is supposed to compensate for the weight of a full gas tank. But you are right, a full tank of gas is over 200 pounds.
Old 07-20-2005, 10:58 PM
spudglo08 spudglo08 is offline
Send a message via AIM to spudglo08
wow my dads suburban sits level on all 4 sides must be the autoride suspensions self leveling or somthing but my 97 Z71 sits about an inch off in the front compared to the back.
Old 07-20-2005, 11:01 PM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
no thats so you can use your truck...IE put sh!t in the back...
'99 Silverado 4 x 4
bunch of goodies
Old 07-20-2005, 11:21 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: Re: Re: One side of truck sits higher
Yeah, it's called "rake"
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-22-2005, 10:25 AM
TexasF355F1's Avatar
TexasF355F1 TexasF355F1 is offline
Send a message via AIM to TexasF355F1
The 1" offset is known as the "Chevy Lean". S-10s do it and so do the new Silvys. Chevy just can't get their shit together.
*Under Construction - New sig to debut*
