Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 07-18-2005, 09:48 PM
partsguy53 partsguy53 is offline
Unhappy Howling noise from air filter housing
What's causing the noise coming from the air filter housing? Does it when my 1997 4.0 XLT Extended A-star gets warmed up. I think the box vibrates when air goes through it but WHY? Can it be corrected? Only has 77k on it.
Always something to do...
Old 08-09-2005, 09:49 AM
Rmasters3 Rmasters3 is offline
Howl
Most likely it's your Idle Control Valve. Two screws, an electric plug, and about $50 fixes this.
Old 08-18-2005, 09:32 PM
tknepper17268 tknepper17268 is offline
Send a message via Yahoo to tknepper17268
howling noise
Hello there take the air filer out and check the bolts on the box to make sure it is tight. I had the same problem if that is tight then it is the airflow sensor but they are only about 25.00 at advance auto napa is 30.00 let me know if this helped travis
