Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-18-2005, 07:25 PM
1blackcrownvic's Avatar
1blackcrownvic 1blackcrownvic is offline
horn wont work 98 cvpi
my horn suddenly stopped working on my vic,.i checked the corresponding fuses/relays, but no dice..can it actaully be that both horns just up and died?
(note..i almost NEVER used my horn, now that it doesnt work, i find i need to use it ten time a day!..jersey drivers! !arrghh)
Old 07-18-2005, 07:56 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: horn wont work 98 cvpi
Check for current at the horn while the button is pushed. If no current, look to the relay. If there is current, replace horns.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-19-2005, 09:49 AM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
does your cruise and air bag work also ahat i mean is does the air bag light come on at all while driveing because if the cruise doesnt work also i would say you have a bad clock spring had one go on my 92 grand marquis and replaced it now i have my horns and cruise
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 07-22-2005, 11:08 PM
FOLKS;
NO CRUISE, BUT ILL TRY TESTING IT FOR POWER..THANKS AGAIN!
Old 07-23-2005, 09:05 AM
im willing to bet thats its the clock spring thats givin u the trouble
Old 07-26-2005, 05:20 PM
okay,..ill bite.. what in blazes is a clock spring, and more importantly..where is it located?.. i should also make clear that i DONT have cruise control..but im thinking of putting it in, i heard its just a matter of installing a harness or something..if i have to replace the horn switch in the steering wheel, im thinking that would be an ideal time to kill two birds with one stone.. whaddya think?
Old 07-26-2005, 06:42 PM
way2old's Avatar
TOKEN HILLBILLY
To follow up on cobradude's post, the clockspring is inside the steering column. You need to remove the steering wheel to gain access to it. It is a tape designed wiring component that carries the current to all the electrial switches, including the air bag. Just for giggles, try to hold the horn button down while you turn the steering wheel from lock to lock. If horn works anywhere in between, clock spring is bad. But, check for current at horns first.
