Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 07-18-2005, 06:59 PM
speedncivic speedncivic is offline
96 civic to be lowered
I am planning to lower my civic in the next couple of weeks but need some help. I have a set of dropzone struts and coilovers +/-3". I could really use some help with the install. Also do I need a camber kit? Any recommendations?
Old 07-19-2005, 11:55 AM
BullShifter's Avatar
Re: 96 civic to be lowered
First rec. sell your current setup and get something good.
If you lower more than 1.75" yes you will need camber kits, stay above 1.75" and you can get away without having them.
Most people don't understand what adjustable height suspension is for or how to use it properly. So your best off sticking normal lowering springs and a good set of struts.
With adjustable height you WILL need an alignment with every height change, also corner weighting should be done every time as well.
Buy a repair manual from www.helminc.com
Old 07-19-2005, 11:00 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
3" on dropzone struts there not going to last.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
