Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 07-18-2005, 07:52 PM
99hcguy 99hcguy is offline
got problems
i have a 99 ex i put an engine from a 98 ex in it. vacunme line is missing and check engine light is on. my car jerks (shifter also) when i press on and off the gas but in between its fine except when i'm going slow then my car shakes like its going to stall but i'm in a low gear so its all messed up. i have the old engine and thinking about rebuilding it (rod bearings went). but i don't have that much money to spend need some help thanks
Old 07-18-2005, 08:24 PM
ridestreet84's Avatar
ridestreet84 ridestreet84 is offline
Send a message via MSN to ridestreet84
try just putting on the other intake manifold and the fuel rail and injectors from the other engine. i know that when i replaced my engine i just used the old manifold and fuel rail and no check engine light.
Goodbye civic Hello turbo outback goodbye outback Hello WRX
Old 07-18-2005, 11:16 PM
Re: got problems
i did that when i was putting the engine into the car didn't notice it until i got the engine in and started the car (vacume leak)that the manifold didn't match up to the head
Old 07-21-2005, 06:21 PM
i hope all your problems have been fixed and the info helped
Old 07-21-2005, 09:51 PM
still have the problems i don't know what else to do i have the old engine i think i'm just going to get it rebuilt and see what happens or end up going to the honda dealership
Old 07-24-2005, 11:08 AM
sohcfreak97's Avatar
sohcfreak97 sohcfreak97 is offline
Banned
Re: got problems
why dont u just block off the vacuum line, or run it to a vacuum source...tahts why ur car wants to stall out at idle, it has a vacuum leak
Old 07-25-2005, 12:00 PM
_93civchatch_ _93civchatch_ is offline
Re: Re: got problems
yeah, and if you cant find where the leak it, spray some wd40 around your engine, and when you spray the leak your car will rev up.
