Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 07-18-2005, 06:08 PM
1993 Jimmy 1993 Jimmy is offline
Send a message via Yahoo to 1993 Jimmy
Rough Idle and starting problem
Ok, I'm new at this, but here I go. After reading ALOT of the past messages that other people have posted I have almost fixed my problem. I thank you all for that but here is my current problem.
I have a 1993 GMC Jimmy with the 4.3 liter W motor, it had a rough idle, starting problems, hesitation, and surging. I changed the fuel pod, spark plugs, wires, and cleaned, and cleaned, and cleaned, and pulled the EGR valve and cleaned it too (it was stuck open).
I was wandering if anyone could tell me if there was anything I could use to clean the carbon off the bottem part of the intake without having to pull it all apart again? I just do NOT want to pull it apart again.
Also I plan on modifing it to RUN like a V-8 instead of a V-6, any good sites I need to Know about?
Thanks
Steve
Old 07-20-2005, 11:07 AM
Re: Rough Idle and starting problem
Does any one have any Idea about getting the carbon out or any mods I can make to the engine?
Old 10-19-2005, 04:29 PM
taylorman taylorman is offline
check fuel pressure. If good then check your cpi system.
