Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-18-2005, 04:38 PM
Voodoo302 Voodoo302 is offline
Unhappy '97 jetta will not start
i've got a '97 jetta trek, manual trans., that suddenly won't start. i replaced the ignition coil a few weeks ago to fix some post-rain sputtering problems (which it did, until two days ago), and ever since i replaced it, it's sounded like it's grinding harder when it turns over.
today, when i started it up, it had gotten worse. i took it to get new tires and when i picked it up it turned over twice and from then on, nothing. we push-started it and it ran completely normally all the way home, but once i turned it off it wouldn't restart.
my battery's fine, i have all my accessories working, and when i turn the key i get a high-pitched whine...almost like something's spinning but not catching. i put the old coil back in to see if the new one was the problem but no luck. and yes, i'm making sure the clutch is fully depressed.
any ideas? please help!
Old 07-25-2005, 07:10 AM
98R/TDailyDriver's Avatar
98R/TDailyDriver 98R/TDailyDriver is offline
Send a message via AIM to 98R/TDailyDriver Send a message via MSN to 98R/TDailyDriver Send a message via Yahoo to 98R/TDailyDriver
Re: '97 jetta will not start
Try the starter solenoid...
Old 07-27-2005, 07:30 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Sounds like the starter is shot. I believe new ones come with a new starter solenoid on it.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-31-2005, 07:28 AM
thanks for the advice guys...it was the starter.
by the way, be wary of non-OEM parts from NAPA. i got a rebuilt starter from them and the solenoid had totally different connections than my original, i lost probably 3 days in my repair because of this.
