Old 07-18-2005, 04:19 PM
skotman's Avatar
skotman skotman is offline
My Aching Struts!!
whenever i make a lefthand turn in my 89 crx dx (stock engine, no major mods) i here and feel creaking and squeaking coming from the front of the car. as i said, i can actually feel it in the steering wheel. kinda feels like rubber against rubber...
if i leave my wheels turned left and get out of the car and press the whole car down by the front left fender area i can hear what sounds like the strut squeaking and creaking.
so, folks, i guess that means my left front strut is dying. it's a wonder it's lasted this long. 16 years old, and i never slow down for speedbumps, potholes, etc. then again, sometimes you don't see the potholes until it's too late (my first car, an 85 crx, had frame damage from a hole in the road so deep that the towing hook got caught slightly in the other side and warped the frame it still drove fine, but was slightly uneven when you looked at it head-on)
i'm a bit tired of messing with changing things on my car myself. i am probably still discouraged by the fact that i couldn't change the timing belt due to a stuck-fast nut. a place up the road could do the struts for about $160 (if i remember correctly) per side. sound like a good deal? just gonna be generic after-market struts.
Old 07-18-2005, 06:17 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
Re: My Aching Struts!!
Thats way to much. A shop down here does all 4 for $100 and they get it done right and in about 2 or 3 hours. Its not really that hard at all to do it your self, i have done it many times, just a litte time consuming.
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
Old 07-18-2005, 06:39 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
The squeaking could also just be old bushings - mine do that every now and then and i either just wash the car and get the dirt out of them or spray them with wd-40 and it goes away for a while.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 07-18-2005, 08:17 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
could also be strut bearings. does it squeak as you turn (while turning the wheel) or does it squeak when your holding the wheel during a turn.
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 07-19-2005, 12:11 AM
Mine squeked all the time when hitting bumps and pulling into driveways with a small hill. I squirted some oil down into the strut and it hasnt squeked since.
94 B18B Engine
OBD-1 Conversion
DC Sport Header
Short throw shifter
MUCH MORE TO COME!
3" SR20Det downpipe
3" Test pipe
Old 07-19-2005, 07:03 AM
skotman's Avatar
i DID get a lot of dirt under my car recently due to rain+dirt road. i'll see if that's what's causing it, cause it only began after it got dirty.
yeah, it squeaks as i'm turning left. it only squeaks while the wheel is turned left a bit. if the wheel is strait, and i push the front end up and down, no squeaking.
Old 07-19-2005, 12:09 PM
BullShifter's Avatar
I would check the ball joints and tie rods. If one of those babys lets go at highway speeds you could be in for some serious pain.
Lift left front corner so the tire is not touching the ground. Grab tire and rock in all direction, if any play is felt its highly likely to be ball joints or a tie rod. Once play is felt a further inspection of the 3 joints should be done to determine the faulty part.
Throwing uneeded parts at a car is dumb especially when it could be a safety issue.
