Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-18-2005, 02:22 PM
mydogpeanut mydogpeanut is offline
Question 2001 Jetta Radio Not working at all
Hi All,
Ok so I have a 2001 Jetta and all of a sudden my radio is not working. I went away on vacation for a week and came back to a radio not working anyone know what this could possibly be? I do know that the radio was working before I left and that while I was away some one did use my car (with the valet key if that matters) but claims that the radio never worked for him?
How do I get the radio to work again?
Any help/suggestions would be greatly appreciated.
Thanks
Old 07-18-2005, 02:28 PM
98R/TDailyDriver's Avatar
98R/TDailyDriver 98R/TDailyDriver is offline
Send a message via AIM to 98R/TDailyDriver Send a message via MSN to 98R/TDailyDriver Send a message via Yahoo to 98R/TDailyDriver
Re: 2001 Jetta Radio Not working at all
Is it the monsoon? -I had to take mine out, pull the fuse (on the back of the radio) for a few minutes -put it all back and it was good! Although I had to borrow a radio removal kit from a buddy...
Old 07-18-2005, 02:31 PM
Re: Re: 2001 Jetta Radio Not working at all
Yes it's the Monsoon. That's what I was thinking it was. Just wanted to see if anyone else has had this problem. Now where to get a radio removal kit
Old 08-25-2005, 01:58 PM
ok so it wasn't the fuse. Pulled the radio out and the fuse was fine. Put the radio back in and it still didn't work then a few days later it just started to work again.
Now about a week ago the radio was working fine when I parked it at the T station before work... end of the day I get back to my car and the radio is not working again...
any ideas??
Old 08-26-2005, 04:56 PM
boschmann boschmann is offline
If the only thing that works is the blinking theft light then it is an internal failure which is fairly common. Pulling the power will sometimes reset it, but eventully it will die again.
Old 08-29-2005, 10:04 AM
The theft light on the door that blinks is working but no power to the radio at all. Is that what you were talking about? I will try and pull it... hopefully that works...
Old 09-19-2005, 11:15 AM
Re: Re: Re: 2001 Jetta Radio Not working at all
Still not working
Could it be the wire harness?
Is that hard to replace?
Old 09-19-2005, 05:05 PM
Dead radio.
Old 09-19-2005, 11:04 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
replace the radio
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 09-27-2005, 05:52 PM
1.8TVWCraze 1.8TVWCraze is offline
Send a message via AIM to 1.8TVWCraze
Talking Try this
It could be the fuses on the side of the door. When i had that same problem i had to check everything, the only way i fixed it was when i pulled the fuse from the side and it was messed up, it was connected but alot of corrision was on the fuse. When i replaced it, it started working fine. It could be that or a defective radio.
Old 10-04-2005, 10:05 AM
CaptainBennett CaptainBennett is offline
Is the cost of taking it to the dealer going to outweigh the cost of buying a new unit?
My Monsoon still appears to be working OK on my '02, but I'd like to get something new that allows me to use my Ipod with the interface.
