Old 07-18-2005, 01:27 PM
grease monkey girl's Avatar
grease monkey girl grease monkey girl is offline
back with a problem
ok, here's the sitch. I was sitting in traffic for 3 hours on Friday (gotta love LA) and after a few hours of sitting there, I tried to speed up - 1st gear, totally cool, 2nd gear totally bogged down and jerked hi rpm -lo rpm - hi - low. Then it was ok. So this morning (after letting it sit for the weekend) and the ride was very jerky and it would not accelerate, I lost all speed going up an incline and if I put the pedal to the floor, it wouodn't move. The SES light did not come on, I checked the codes, it is not flashing any. Fluids are good. The alternator belt is cracked, but I wouldn't think that was the problem (though I do plan on replacing that immediately). So what's the opinion?
Old 07-18-2005, 11:53 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: back with a problem
check your tranny fluid, for both level and color/smell. other than that, it might take a road test with a tech I plugged in to watch the sensor data and look for something out of the ordinary.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-18-2005, 11:54 PM
ct91rs ct91rs is offline
Are you one of those valley girl types? I caught "totally" a few times. Nothing personal
I'd start with checking the fuel pressure, maybe a clogged filter/failing pump. If that's ok, then rule out a plugged cat, bad ignition module...
Old 07-19-2005, 12:02 AM
89IROC&RS's Avatar
i dont know if id call grease a vally girl.........
Old 07-19-2005, 11:46 AM
Re: Re: back with a problem
thanks for backing me up on that..... I am absolutely not a valley girl although I did say totally twice within the period of six words
I am going to be checking everything today. My brother said it might be fuel also. I REALLY hope it's not the pump, I absolutely don't have the $$ or the means to fix it myself thanks guys
Old 07-19-2005, 12:03 PM
Morley Morley is offline
Re: Re: Re: back with a problem
Check the trans fluid mentioned above (doubtful it would cause bucking). Then check the fuel pressure. Not just at idle (if idle looks good), tape the FP gauge to the windshield so you can see it as you drive. If it takes a nose dive while driving you cn start by replacing the filter and see if that fixes it...if not and idle pressure was no good. Get some clamps to pinch off the fuel hoses (vice grips with the jaws wrapped in tape will do). Pinch off the return line and turn the key on and watch the pressure...is it good? If not you have a bad pump.
No special tools are needed to change the pump, just a day, a friend/helper, jack & stands. The pumps cost less than $50 at most parts stores.
Old 07-19-2005, 06:07 PM
now is the fp gauge already in the car, or do I have to purchase that? I know, it sounds like a dumb question, but I am learning as I go
Old 07-19-2005, 09:07 PM
hey grease. i was just funnin' with you.
Unless someone installed an aftermarket f/p gauge, you won't have one in your car. You'll need to borrow or buy one. Keep in mind that the type of f/p test gauge you get will depend on whether you car has TBI or TPI, the connections are different.
Old 07-20-2005, 02:02 AM
You want a gauge with a hose long enough that you can tape the gauge to the windshield so you can observe it while driving.
And if you need a step by step on pump replacement can do that too...I've done several of the in tank pumps.
Old 07-20-2005, 02:44 AM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Sounds like your throttle position sensor, thats what my problem was, car got kinda hot to the point that the fans came on, tried to step on the gas and the Maro would move slowly up.. very ghey..
About RPMs ICM, yes thats my solution to everything that has to do with RPMs and im sticking to it, also STP.
Old 07-20-2005, 12:28 PM
would the throttle position sensor come up in the codes? I just replaced the ICM about a year ago, so I don't think it's that....
I replaced the fuel filter last night, and, although it was clogged, it was not the problem. I checked the tranny fluid, clear and full. I didn't get a chance to check the spark plugs because it got dark, so I still have to do that, but I really don't think that's the problem either.
Old 07-20-2005, 12:35 PM
Not always.
Old 07-20-2005, 01:12 PM
Originally Posted by Morley
Not always.
so is there a way for me to check it before replacing it, or do I just replace it and see if that was the problem?
One other thing - my oil pressure is low even though the oil is full.
Old 07-20-2005, 03:22 PM
Re: Re: Re: Re: back with a problem
advance auto, autozone can test it, but you have to take it off.
Old 07-20-2005, 03:29 PM
Is eating.
The TPS if I remember correctly didnt cost alot..I think around 15 bucks or so.. but hey do put some good STP in your car if you havent lately like RX7 or something like that which I heard is really good, I might be wrong but doesnt hurt because my bro's Lancer started jerking around a bit when we were in Vegas because of all the gas we have been putting in and different formulas because of elevation.
