Go Back   Automotive Forums Car Chat > Honda > N2O | Turbo | Superchargers
N2O | Turbo | Superchargers Tech forum to assist in Honda/Acura Performance.
Old 07-18-2005, 11:40 AM
TopSecretHatch's Avatar
TopSecretHatch TopSecretHatch is offline
Send a message via AIM to TopSecretHatch Send a message via Yahoo to TopSecretHatch
I need help! best way to boost B18C
Okay... i drive a B18C powered civic hatch... LSD transmission. AEM cams, fuel rail, and filter. Fuel pressure regulator, intake, custom exhaust. Now, what I wanna know is... whats the best way to boost it, without a like $3000 kit from Greddy or something like that. Am I going to run into some shit like intercooler plumbing fitting problems or anything? Anyone know of a good, cheap boost set up?
I had also asked a dude who tuned a p72 Ecu for my car about what i would need to do if i boosted, and he said ide have to get a different ECU kuz it would fuck up kuz of the retard.... ?
What about those ebay kits? Anyone had any experience with those? I wouldnt get one.. but just wondering if anyone has, and what happened. Thanks!
Hatches of the world unite!
Old 07-18-2005, 12:20 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: I need help! best way to boost B18C
you could build your own kit pretty cheap.. or you could buy one, stay away from ebay (IMO). and the person that said you need a new ecu.... if its already chipped, just re tune it... if its not, chip it.. it would be a hell of a lot cheaper than buying a different ecu.
Old 07-18-2005, 12:41 PM
sivic02's Avatar
sivic02 sivic02 is offline
First of all the words boost and cheap should never go together. You dont want to just pick up cheap parts, half ass what you dont want to pay good money for. Spend the extra ammount of cash and go with a quality setup. You can do this two ways. You can either pick up the pieces yourself and piece it together, get someoone to bend your tubing for you. Or you can just pick up a GOOD kit (not greddy or e-bay). If I were you I would check out cybernation or rev hard.
And you are right, the retards are usually what fucks things up.
Here's to being single, seeing double, and sleeping triple
Old 07-18-2005, 01:09 PM
turboEKhatch turboEKhatch is offline
You have AEM cams, yet AEM doesn't make cams.
Interesting.
Old 07-18-2005, 01:16 PM
Kind of a Big Deal
ill put money on he has AEM Cam Gears and not cams.
Old 07-18-2005, 02:26 PM
Re: Re: I need help! best way to boost B18C
I'll put money that if he had the things he would probably know the difference.
Old 07-18-2005, 03:16 PM
sivic02's Avatar
Wait you guys mean cams and cam gears arent the same thing?
My conclusion is this guy should not turbo his car. Not because he aparently has no clue what is even in his engine, but because the imaginary aem cams are probably waaaay too aggressive for a turbo setup.
You could always run a huge shot of nitrous, im thinking 250 shot dry, if you run one that big make sure to lean out the fuel and advance the timing.
Old 07-18-2005, 03:18 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: Re: Re: I need help! best way to boost B18C
ill put money that he has no idea what cams or cam gears are
Team Lonely Drivers
Old 07-18-2005, 03:32 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
God you wovles are pissy today!
he missed the word gears give him a break.
now honestly you didnt specify it it was an ITR motor or a GSR b18c.
You should go to obd1 cause its better its that simple as a start. easier to tune by a ton.
Now whats your budget and goals you left us pretty open ended man.
Old 07-19-2005, 03:05 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
http://www.beesandgoats.com/boostfaq/g2icturbo.html
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 07-19-2005, 09:26 AM
thanks a lot sivic and greenblurr... and i did mean cam gears... jeeze.. people jumpin all over everyone and being assholes because of a typo. I did the enginge swap myself ass... i think i have a pretty good idea of whats going on. Ive never boosted a car before, and I heard that civics arent the most boost friendly... so just wanted a little bit of heads up. ---Thanks for most of your replies-
Old 07-19-2005, 09:32 AM
alphalanos alphalanos is offline
dont mean to jack the thread, but what do you guys think of Turbonetics kit? claims like 8 psi and costs $3,400. I think its overpriced.
96 EJ6. Future home of boosted B18C1.
Old 07-19-2005, 09:45 AM
alright ace: 1996 B18C JDM Integra Type R motor
Already did the OBD1 conversion, running a chipped ECU. I had the ECU stuff done for me kuz im clueless about the ECU stuff. I heard a lot of people do hondata when they get turbo.. but that shit is expen$ive. Also, I have a 255 lph walbro fuel pump on switch... do I need to beef up the injectors if I set up a turbo?
my budget... around $1500 in parts. Me and my buddy can put the kit together.. but I want to know what are recommended in terms of parts. What size turbo, brands, what psi to run, stuff like that. Thankz again for your help.
Old 07-19-2005, 12:17 PM
Kind of a Big Deal
upgrade your injectors wouldnt be a bad idea, have you strengthend your bottom end at all? if not i wouldnt go much above 8-10 psi depending on the kit.
Old 07-19-2005, 12:33 PM
Ace$nyper's Avatar
Banned
ah ok so it's an ITR motor/ first off what are your goals power wise? 5-6 psi be fine stock anything more pistons are a good idea.
god knows what your ECU is doing is there a way to find out? I use Chrome for my tuning much nicer then uberdata and cheaper then hondata.
