Spark Plug Gap!
I hear lots of people argue on spark gap. I heard .026 to .032 is the best range anything high than that on a turbo car you get spark blow.
92 Stealth R/T TT CURRENT MODS: K&N FIPK Spec Stage 3 Clutch 6 Puck HKS Turbo Timer Type-1 3 Inch Polished Y-Pipe Greddy Profec B Spec II @ 12.0psi Greddy Type S BOV Greddy Catch Can Borla Exhaust 3 Inch SS Down Pipe with Race Pipe 3SX Crank Pulley Accel 8.0mm Wires Gen 3 Lifters High Flow 290lph Fuel Pump (Supra Pump) Plugs Gapped at .030 Iridium IK20's 550cc RC Engineering Apexi S-AFC II (WILL BE REMOVED NOT YET) 2 G-16 Turbos AEM EMS FUTURE MODS: Custom FMIC |
Re: Spark Plug Gap!
Most people running stockish boost levels generally have a gap of .036, but most of them who are mildly modded will go down to 0.032, which is probably the best place to start out at, cause you want the widest gap possible without blow out. Then, those who still experience blow out at 0.032 will go down to 0.028. Looking at your sig, i'd start out at 0.032 and then gap down only if spark blow out occurs.
Daily Driver: 2004 Jeep Grand Cherokee Special Edition 1994 Mitsubishi 3000GT SL-TT Automatic - Black 3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods 1994 Mitsubishi 3000GT VR-4 - Black Intake & Boost Controller so far 2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods |
Re: Spark Plug Gap!
i thought the gap is .044, but then again its probably dif. on turbos.
Re: Re: Spark Plug Gap!
mitsu's specs for non-turbos are 0.044 and for turbos are 0.040, although 0.040 IMO is too high of a gap for the TT's as it usually does cause blow out. non-turbos do not have to worry about spark blow out like TT's do. This is due to the fact that TT's throw in pressurized air into the cylinders, so it takes more energy for the spark plug to ignite a spark. If your gap is too high, then the spark cannot overcome the pressure and can't make a sufficient spark causing the engine to stutter.
Re: Spark Plug Gap!
So even if an NA was modded, we still won't have to worry about spark blowout and just stick with the 0.044 gap?
Re: Spark Plug Gap!
Sweet, sounds good. One more question....what if we SC it? Would we have to worry about blowout or will we still be good? Thanks for the help.
Re: Spark Plug Gap!
Yes then you would need to worry about it, because again, your air in the cylinders would be pressurized...just like a turbo.
96 3000gt vr4 -K&N FIPK -Proboost mbc -Cusco front + rear strut bars -Greddy type-s -ATR downpipe -no cats -15Gs, 3sx aluminum pulley, FMIC, SAFC, walboro pump, EVO 560ccs, and Meth Injection Kit all waiting to go in shortly. Your 1996 Mitsubishi 3000GT VR-4 is the 92nd out of the 315 that were made that year. Only 21 of which are exactly identical. |
