Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-18-2005, 07:14 AM
98R/TDailyDriver's Avatar
98R/TDailyDriver 98R/TDailyDriver is offline
Send a message via AIM to 98R/TDailyDriver Send a message via MSN to 98R/TDailyDriver Send a message via Yahoo to 98R/TDailyDriver
Arrow P0420 Engine Light 02 Jetta
I have an 02 Jetta with the 2.0 engine. I have 69000 miles on it 30000 put on this year.
The engine light came on a last week on my way to work. I disconnected the battery to reset the light and assumed because the car is running fine that it was because of the humidity.
A couple days later it came on again so I pulled the codes and got:
P0420
Catalyst Efficiency
Below Threshold
(Bank 1)
I thinks it is one of 3 things
1) O2 sensor
2) MAF sensor
3) Bad gas
I ran the gas nearly empty and filled up at a reliable station and the light is still on -I am going to clear it tonight and see if it remains off.
If it comes back I will probably clean the MAF, and if is comes back after that I will replace the O2 sensor.
I was just wondering if anyone had a similar issue or has better ideas...
Old 07-20-2005, 08:08 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
more likely a bad cat than any of those other ones.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-21-2005, 10:07 AM
Re: P0420 Engine Light 02 Jetta
Bad cat? That would really suck!
I ran the car near empty a few times and filled it up with good stuff -not high octane just good 87. I cleared the code and it has been off for about a day.
Hope its not the cat...
Old 07-24-2005, 12:46 PM
VDUBMAN
Cat is covered under warranty 8yr 80k miles
Old 07-25-2005, 07:04 AM
How would I know if it is the cat? Should I bring it in?
Old 07-27-2005, 06:32 AM
Talked to a VW dealer -they said 7-70 for a warranty on the Cat so I'm SOL.
On the other hand I had the oil changed by a different VW place a few months ago -they overfilled it by at least a quart -I ran it like that for 2 days (260miles) before I could get back to the dealership to yell at them and make them redo it. It says right in the manual, if you overfill the oil it will go out the crank breather and right into your Cat causing damage. I will call them to complain and see if it will get me anywhere...
Old 07-27-2005, 07:37 PM
VDUBMAN
Actually overfilling causes misfires. Misfires eat up a cats internal parts.
Cat should 8yr 80k, check your owners manual.
Old 07-28-2005, 06:23 AM
No luck -I called 2 dealers and both said they cannot help me, both say the cutoff is 70K. The cat is so expensive I may as well get a cat back racing system. If the cat is bad I think I'm going to clean it with a few little tricks or hollow that puppy out if cleaning fails.
Is this code coming from the O2 sensor or is there a sensor right in or after the cat?
Old 07-28-2005, 09:09 AM
CaseyVR6 CaseyVR6 is offline
Re: Re: P0420 Engine Light 02 Jetta
Unless you live in california you can pick up a new cat for less than $400. If you live in CA, you can find a recertified salvage for about $400. www.convertergeek.com sells aftermarket cats, 1-800-VW-PARTS sells salvage parts. I just bought a reconditioned cat... which brings me to my next question...
Is it possible to trade out the cat myself? I live in an apartment building and only have a small floor jack to use in my carport, but a full set of tools. What is involved in the job??
Old 07-28-2005, 10:00 AM
Yeah I found an aftermartket replacement for 261 at autoparts.com.
The replacement shouldn't be too hard but I noticed that the cat is a large section of exhaust rather than just being a small section. I'm thinking of cutting the cat section out, cleaning it myself and then clamping it in back in place. I am going to do mine on ramps.
The car should pass emmissions without a cat...
Old 07-29-2005, 10:20 AM
Doug Tatham Doug Tatham is offline
Bad Cat?
The reason the Cats have such a good warrenty is that they don't usually go out.
There are a couple very inexpensive possiblities, both have given me the same error. Rember that fuel mix problems will lead to emmission problems that are mistaken for a bad cat.
1. Bad air filter. This can cause an improper mixture and an overy rich mix can lead to a cat error.
2. Fuel pump (not so inexpensive). Check you fuel pressure.
I have found that the cats tend to last for the life of the car unless your mixing coal with lots of sulfur with your gas. From what I've seen, corrosion tends to be the number one killer of cats.
Old 08-01-2005, 06:33 AM
Yeah, the cat in function is very simple and should last the life of the car. Unless the catalyst metals inside become covered or clogged.
I drove for a week with the engine light on and then it just went off. Its been off for a couple days -I'm just going to leave it alone.
