Old 07-18-2005, 01:41 AM
adamam adamam is offline
Vibration when stopped and foot on the brake!
When I am idle at a stop light with my foot on the brake I have a slight vibration throughout the car. What is this?
adam
Old 07-18-2005, 06:06 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Vibration when stopped and foot on the brake!
it sounds like you might have a bad motor mount? how bad is the vibration? is there any sound?
Old 07-18-2005, 08:42 AM
no, not sound at all.
Old 07-18-2005, 07:23 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Sounds like your torque converter is not releasing fully. Try changing the transmission fluid and filter, this should clear things up.
Old 07-18-2005, 09:58 PM
Hoags's Avatar
Hoags Hoags is offline
How many miles on the car? What year and engine? It could be one of many things, like the torque converter or a bad mount or even something as simple as a bad spark plug.
Old 07-18-2005, 09:59 PM
ok
60,000 miles. 2001 GASE.
Old 07-18-2005, 10:53 PM
Hoags's Avatar
Does it only vibrate when you have your foot on the brake, or will it happen in park? If it is only happening with your foot on the brake it is most likely a vacuum issue. Also will it do it if you are stopped with your foot on the brake and the car in neutral?
Old 07-19-2005, 12:00 AM
the car does it when I stop and keep my foot on the brake, but not in neutral.
Old 07-19-2005, 09:04 PM
Hoags's Avatar
Chances are that you have some type of vacuum problem since applying the brakes requires use of the vacuum system.
