Old 07-18-2005, 01:20 AM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
piping size?
well i have a few questions. for an exhaust what size would work the best 2.5 or 3? and on the intake side does the size of the pipe really matter as far as how it fits on the turbo?
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 07-18-2005, 01:21 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: piping size?
3 if you planning on upgrading the turbo anywhere in the near future.
95 Talon TSI AWD
97 Eclipse GST
Old 07-18-2005, 01:29 AM
blk_srt's Avatar
Re: piping size?
another thing that i forgot, how much difference is there between a t28 and a 14b as far as boost levels?
Mods:
Old 07-18-2005, 02:51 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: piping size?
Don;t think in terms of boost levels, think in terms of airflow. Boost = heat, airflow = power. That being said, a T25 maxes out between 22-55 lbs/min, and a 14b is good to a solid 30 lbs/min. Of equal importance is the upgrade in turbine wheel/housing size, which reduces intake to exhaust manifold pressure ratios (increases VE for more airflow at same boost level). Ultimately the T25 will only hold about 13 psi to redline, while a 14b will hold 23-25 psi. The 14b is the better turbo for all these reasons and more.
I would go straight to the 3" exhaust to avoid having to upgrade twice. Be prepared to deal with boost creep with a 14b. A larger smooth intake will increase aiflow at the same boost since it will lower the pressure ratio. On a 14b, my home depot 3" ABS intake was worth ~50 Hz IIRC. Hard to translate that into power or performance numbers, but it was a clear improvement none the less...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-18-2005, 07:09 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: piping size?
Wow, I wish my old t25 would have done 55lbs/min.
Kevin ment 22 - 25lbs/min.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
