Go Back   Automotive Forums Car Chat > Honda > Wheels/Tires/Suspension
Wheels/Tires/Suspension All the handling help you need. No matter what Honda/Acura you drive.
Old 07-17-2005, 10:21 PM
paliagp paliagp is offline
Arrow Camber Question??//??
hey all,
i was looking at my teg today and i noticed that i have negative camber in the rear. Is rear camber adjustable and if not, how can I fix it??
thanks
Old 07-18-2005, 12:48 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Camber Question??//??
buy a kit or use the bolt and washer method.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 07-18-2005, 01:51 AM
BullShifter's Avatar
no camber is not adjustable
if the negative camber isn't extreme you can fix it with the "washer trick" Just make sure to use grade 8 or better bolts. Ingalls can supply with all the correct "strong" bolts and washers or do it yourself - http://home.earthlink.net/~civicex95/rearcamber.html
Old 07-18-2005, 04:48 PM
thanks for the info guys....now i know what camber is but i dont really know what causes it....can parts be replaced to fix camber??and is the bolt and washer method just as good as a camber kit??
Old 07-18-2005, 09:48 PM
glassman556 glassman556 is offline
buy a rear camber kit off of ebay.. it's simple to install i did it to mine.. easily adjustable and about 10 minutes to put on..
Old 07-19-2005, 12:29 AM
AF - Advisor
Re: Re: Camber Question??//??
very effective and should cost less than $8.
Old 07-19-2005, 11:37 AM
Camber is usually affected by
1. Lowering the car
2. Bent suspension parts
If the negative camber isn't sevre I would do the washer trick(with good bolts) before I bought some junk from ebay.
If the car isn't lowered your best off replacing the bent parts instead of trying to bandaid it with an incorrect repair( camber kits or bolts/washers)
Old 07-19-2005, 03:36 PM
junk off ebay??? if you know how to use e-bay.... or excuse me know what your buying off of e-bay and know it's not some cheap rip off gimick you'll do just fine.. junk?!?! know what your doing and get the right thing..
Old 07-19-2005, 05:21 PM
94PreludeJDM's Avatar
94PreludeJDM 94PreludeJDM is offline
the camber kits on e-bay are, by in large, junk. Numerous people have had problems with e-bay camber kits. If you haven't and you bought a quality part, super, good for you. E-bay is great for some things, but when it comes to suspension, I want to know exactly what I'm getting, because putting in bad suspension parts can make your car very unsafe. Just my two cents.
Old 07-19-2005, 09:48 PM
100%
