Old 07-17-2005, 10:18 PM
brentmcq brentmcq is offline
Posi Rearend
Anyone know of a good place in Phoenix or Scottsdale to swap out a 1 wheel wonder with 273 gears for 373 posi. It's going in a 73 Camaro that will be street / strip pushing 450HP+.
2000 GT 4.6L 5spd, BBK cold air, BBK 75mm TB, Bassani catted X-pipe, (no headers) FM catback, 390 gears, SCT chip, Steeda Pulleys, ported stock plenum, Comp Cam XE262AH. RWHP 260, Torque 282
Old 07-17-2005, 10:27 PM
NoRiceHere01 NoRiceHere01 is offline
Re: Posi Rearend
nope not a clue i live in new jersey. i was just wondering if u have any e.t.'s for the mustang and if so wut r they? please dont crucify me for asking that on a camaro forum i am a chevy guy, im just curious.
Old 07-18-2005, 12:42 AM
I sold the Mustang awhile back, forgot to change my signature. I was running 13.8 @ 102 MPH in the Mustang. Lousy 60 ft times, couldn't hook up well. Now I'm driving a Magnum Hemi wagon for my daily driver and will be starting a new Camaro project soon.
Old 07-18-2005, 09:22 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
Re: Posi Rearend
i live in va, so i cant help either, surry.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-22-2005, 08:07 AM
SpikeD SpikeD is offline
Send a message via AIM to SpikeD
Re: Posi Rearend
as long as this thread is on the posi rearead what the differance bewteen posi, limited slip, an a detroit locker, i dono if there all really the same or what. dont they all give you power to both rear wheels instead of just the one?
1991 Z-28 350CID TPI
Old 07-22-2005, 10:22 AM
89IROC&RS's Avatar
Re: Posi Rearend
posi = limited slip, they are essentialy an open rear end but have disk or cone style clutch packs to keep friction on the rear end. this friction keeps either tire from freewheeling from lack of traction and keeps power going to both tires. as long as the clutches are in good shape they work fine. but when the clutch packs wear out you have an open rear end again.
a locking rear uses two meshing faceplates to physically lock the two axles together in strait line performance, the system then unlocks to go around corners and operates like an open rear end.
the improoved version of the locking differential is the geared rear end, like the detroit truetrac or zextel torsn unit. this uses a geared drive that actually sends power to the tire with traction rather than the one thats spinning.
and then there are spools. which eliminate the torque biasing and tie the two axles together perminatley, this is a drag only option, as the two tires cannot change speeds to go around corners.
Old 07-22-2005, 11:43 AM
Re: Posi Rearend
I see now its all so clear!
Old 07-22-2005, 03:57 PM
89IROC&RS's Avatar
Re: Posi Rearend
its what i do
Old 07-23-2005, 04:33 AM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
So given a topic about rear ends and given some really tall stock gearing, what is the typical rear end swap gear ratio?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 07-23-2005, 09:35 PM
89IROC&RS's Avatar
Re: Posi Rearend
it depends, factory ratios were 2.73, 3.27, 3.42, and on some SLP cars 3.73.
for a good all around ratio i suggest 3.42 as a performance setup and 3.27 for economy.
Old 07-25-2005, 08:37 AM
Re: Posi Rearend
what bout a 12 bolt moser you mentioned befor , how bid of a challange is it to replace the one already under tha car, an does it come in 3.42 or 3.73
Old 07-25-2005, 05:46 PM
92zcamaroperson's Avatar
92zcamaroperson 92zcamaroperson is offline
Re: Posi Rearend
moser is a brand. and you can order whatever gears you want if im not mistaken. its just really expensive. like 2500 dollar expensive. But it just bolts right up. And the chances of you ever breaking it are slim to none.
92 z28 camaro 5.7 TPI
current - slp intake runners and base-BBK 52mm throttle body-MSD 8.5mm wires, blaster coil, and 6AL Box-edelbrock headers-160 degree stat.-hotchkis strut tower brace
waiting in the garage - LQ4, milled heads 317 casting (10.5 to 1), hardened pushrods, ported LS6 oil pump, manley dual spings with titanium retainers, MTI X1 cam, hawks longtube headers
Old 07-27-2005, 01:29 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: Re: Posi Rearend
Originally Posted by 89IROC&RS
its what i do
Iroc =
jk bro you got more smarts then most of us put together.
What kinda rear end does the v6 camaro have? I heard that if the right loses traction it will change power to the left rear tire and vice versa, is that true?
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 07-28-2005, 01:15 AM
89IROC&RS's Avatar
Re: Posi Rearend
yup, thats called a open rear end. its assembled in a way that the tire that is spinning gets all the power, and you get no traction.
Old 08-08-2005, 05:51 AM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
Re: Posi Rearend
Is there a kit I can buy to make a rs limited slip instead of putting a whole new rear end on?
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
