Old 07-17-2005, 09:08 PM
skeavs skeavs is offline
Is my amp done for?
I took my amp/subs out of my trunk to make room for a camping trip, and taped up all the wires seperatley(including ground and power). Well there was someone in the trunk said they saw 2 small sparks, today i went to hook everything up and there is nothing, the subs won't turn on and i've tried every different combination for them. I was wondering if these 2 sparks were ground and power touching would that out shorted out my amp?
Old 07-17-2005, 09:22 PM
OffRoadSonoma's Avatar
OffRoadSonoma OffRoadSonoma is offline
Send a message via AIM to OffRoadSonoma Send a message via Yahoo to OffRoadSonoma
Probably. Check all your fuses. They are designed to blow before something else blows up, like your battery.
Old 07-18-2005, 09:57 AM
L|_|da L|_|da is offline
Send a message via AIM to L|_|da
Re: Is my amp done for?
id check your fuses, im assuming everything else works fine?
Old 07-18-2005, 03:46 PM
Re: Re: Is my amp done for?
Didn't I say that yesterday??
Old 07-18-2005, 09:58 PM
Thank you all both, i just got off a 10 hour shift and im on my way to check
Old 07-25-2005, 05:27 PM
Well no fuses seem to be blown is i possible that i need all new wiring?
Old 07-26-2005, 05:21 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
you cant really tell if an agu fuse is blown most of the time. only way to know is replace it
300amp excessive amperage
Alpine H/U-
Incriminator Audio 20.1 @.35
(2) 15" Q's 8 cubes after 80sqin. 28hz
CDT EF-61's
Profile AP1040 on comps
NSB-100
