Old 07-17-2005, 05:12 PM
Riceboy891's Avatar
Riceboy891 Riceboy891 is offline
Spun Bearing
I recently spun a rod bearing in my zc. I pulled off the pan, sure enough there was some flakes of metal down in the bottom. so i pulled the bearing, it was definately the culprit. Anyway the crank looks fine i think i caught it early enough to save it. My question is will the standard set of ACL's work for. I understand that they are all the same size and wont be size matched to each rod like the oem's but how much of a difference will it actually make. Any help would be much appreciated, especially if anyone can speak from experience.
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
KYB AGX Shocks/Tein Springs
"yeah but it has most all of that hp and torque though the entire rpm range, where as a honda, have to be revving high enough that only dogs can hear your motor to make numbers" -TheSilentChamber
Old 07-17-2005, 05:53 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
another zc with a spun bearing. thats the only thing i hate about zc's. happened to 2 of mine. ive replaced with just standard bearings. what you could do to really get it right though is use plasti-gauge. it tells you the clearances of each bearing so you can get the exact fit. look into it, its really cheap
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
