Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-17-2005, 04:13 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Tuning a dual stage turbo setup
I'm in the process of putting together a turbo setup for my '98 RS. I have a turbo XS dual stage boost controller. The lower setting is going to be at about 9 or 10psi, and the higher will be set at 20psi. Obviously I will need different amounts of fuel at these two boosts. I have 1000cc venom injectors (overkill, I know), venom fuel rail, and walboro 255 pump, and a Greddy eManage FMU. Does anybody know how to set this up so that fuel is injected properly? Anybody have experience with a dual stage turbo setup? Thanks!
Old 07-17-2005, 08:00 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
Re: Tuning a dual stage turbo setup
I don't know how the e-manage works, but set that to your injectors and it should make the car run. The airflow sensor will see the boost difference and inject fuel accordingly... the 'accordingly' is adjustable through your electronics. You don't tune much before you get out and run it. Last thing... how do you know how much boost you'll be running? What if you can run 21psi, why run 20? Why 2 stages at all?
Old 07-17-2005, 09:32 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
usually a dual stage boost controller is so that you dont spin a FWD as much off the line.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 07-18-2005, 01:38 AM
Kuhn's Avatar
Well, the whole idea is that one setting is for pump gas (93 octane), and the other is for 110 octane... And for a better launch.
As for deciding on 20psi... it's difficult to say what kind of hp I might get with that. I just don't want to cross 400hp without a Quaiffe LSD, stronger half shafts, and some forged gears... at least. (Feel free to add to that list if I missed something, other than the clutch.)
I'll update this when I get some numbers.
Old 07-18-2005, 02:33 AM
kjewer1 kjewer1 is offline
AF - Advisor
Using the two settings for different fuels makes sense. The thing to be aware of is the different tuning styles that go with each setting. Typically one would tune the pump gas settng with conservative timing and around 11:1 AFR, while on race gas you need (and can get away with) a little more timing and an AFR of around 12:1. I highly recomend tuning with a wideband (3-400 bucks)...
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-18-2005, 03:20 AM
Whathits14 Whathits14 is offline
Hope you have a built engine. For 20psi on a n/t you arae going to need it. do they even make forged gears for nt's?
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
Old 07-18-2005, 06:13 AM
Kuhn's Avatar
I have Eagle rods and JE pistons (8.8:1). I may have to get some gears made... I may have to return all the empties that day!
As for the timing issue, I'm getting a pressure activated timing retard, so that the second I hit 9 or 10 psi, it retards the timing (up to 20degrees). ... And you better believe I'm tuning with a Wideband O2 sensor!
Old 07-18-2005, 06:14 AM
Kuhn's Avatar
Oh yeah, how much do you think I should retard the timing for the higher boost? Thanks
Old 07-18-2005, 01:39 PM
JoeWagon's Avatar
Banned
Only Jake here has a turbo NT that I know of... so don't count on anyone else's guess. 2gnt and dsmtuners have some more people that have done it.
Old 07-19-2005, 01:06 AM
Eagalicious's Avatar
Eagalicious Eagalicious is offline
Hey Kuhn,
Throw some of that cash my way!!
1997 Eagle Talon Tsi AWD
K&N FIPK
The rest is stock but not for LONG!!
Hey.... I had to try
Old 07-22-2005, 04:42 PM
Kuhn's Avatar
I'll race you for it! Second thought... give me a year. lol ...The only time I beat a turbo eclipse I heard a horrible grinding noise and never saw him on Gratiot Rd. again.
