Old 07-16-2005, 04:57 PM
robertjr's Avatar
robertjr robertjr is offline
Question about oil pressure
I have searched just about every thread in this forum for information on oil pressure problems and have come across a lot of good stuff but I have a few questions that I need answered before I try to apply what I have learned. First off my rig is a '76 chevy c10 with 5.7 my question is is the sending unit for my oil pressure gauge in the seem location as newer engine's and is there only one unit or two like the newer one's (all the info I found was on '85 and newer rigs) also would it be to my benifit if I just replaced my sending unit with a new one or should I just put in a mechanical gauge and be done with it. Thanks for any help and or input it is all greatly appreciated.
Old 07-17-2005, 03:55 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: Question about oil pressure
You can get a tee and add a mechanical gauge, and leave the electric gauge too. That's why I did in my 88. I have a gauge on the bottom end (electric) and one on the top end (mechanical) Both are within 2-5 psi of each other.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-17-2005, 04:32 PM
robertjr's Avatar
I will give that a shot. I assume then that I have sending units in both locations on top, below distributor and on the bottom of the block above the oil filter. With the tee your talking about would I remove the sending unit, say from the bottom and install the tee and then attach the electric sending unit to it and then on the other side of the tee attach the mechanical gauge. Is that right?
