Old 07-16-2005, 04:53 PM
Deathofadam's Avatar
Deathofadam Deathofadam is offline
Send a message via AIM to Deathofadam
Tach signal wrong?
I searched for this and suprisingly could not find anything on it. I got an autometer CF tach for my rex. After wiring it in, the gauge seems to be off by about 1000 rpms. I tried wiring it to the tach in the dash, the ecu, and the dizzy. It is off for all of them. Am I wiring it wrong, or is the tach just broken? Thanks
Old 07-17-2005, 04:16 PM
Wait, I lied. It isn't always 1000 over. I guess I've never driven it since it's been in. It appears to be always double. It has a B16 if that matters.
Old 07-17-2005, 05:18 PM
Riceboy891's Avatar
Riceboy891 Riceboy891 is offline
Does it have different settings for 4,6,8 cylinder engines? if so do you have it on the right one?
1990 Civic HB
DOHC ZC *RIP*
SOHC OBD1 ZC
ZC Tranny
P06 ECU
Stage 1 Clutch
I/H/E
B&M Short Shifter
14" Integra Wheels
KYB AGX Shocks/Tein Springs
"yeah but it has most all of that hp and torque though the entire rpm range, where as a honda, have to be revving high enough that only dogs can hear your motor to make numbers" -TheSilentChamber
Old 07-18-2005, 12:40 AM
ATMDC's Avatar
ATMDC ATMDC is offline
yea, i was about to say the same thing, and if thats not the case, you might want to try and exchange the tach for another one because i bought an autometer tach about 4 days ago and it was faulty so i exchanged it and it worked fine.
Old 07-18-2005, 12:25 PM
The same thing happened with the civic. I ran the signal wire to the ecu and it was double. I then ran it to the dizzy and it works just fine. I tried the ecu, dizzy, and stock tach wire, and they all give the same reading.
