Go Back   Automotive Forums Car Chat > Oldsmobile > Ninety Eight
Old 07-16-2005, 03:23 PM
Zan Stout Zan Stout is offline
Unhappy Throttle positioning sensor nightmare
We have replaced the TPS on a 1993 Olds ninety eight and the ECM is still coding a 21 (TPS circuit signal voltage high). We have checked all the wires leading to and from the TPS to the ECM and the CEL is still coming on after a minute or so the rough idle begins. Please Help!
Thanks,
Zan
Old 07-21-2005, 09:55 PM
DrJay DrJay is offline
Re: Throttle positioning sensor nightmare
You should have a feed line with 5v and a return line with 0.3-.7v at idle. Be sure of these specs and it may tell you the direction of the problem.
