Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-16-2005, 03:02 PM
Zan Stout Zan Stout is offline
Throttle positioning sensor nightmare
We replaced the throttle positioning sensor on a 1993 Olds ninety eight and the ECM is still coding a 21 (TPS circuit singnal voltage high). We have checked all the wires to and from the TPS to the ECM, have tried adjusting the position of the TPS to no avail. The CEL comes on after about a minute or so and rough idle begins. Please Help!
Thanks,
Zan
Old 07-18-2005, 01:02 PM
joe4speed joe4speed is offline
Send a message via ICQ to joe4speed Send a message via AIM to joe4speed
Re: Throttle positioning sensor nightmare
I have the same problem with mine. I replaced it about 3 years ago, then it went bad again and affected the idle, gas mileage, and transmission. So I put another one in about 3 weeks ago and now it's doing it again sporadically. I can't figure it out either.
Joe!
1988 Mustang GT
1993 Olds 88 LSS
http://www.joe4speed.com
Co-owner: RiceHatersClub
Old 07-21-2005, 11:16 AM
Hansnet's Avatar
Hansnet Hansnet is offline
put a dmm on it Terminals A and C tell me what the idle voltage is.
Old 09-05-2005, 12:04 AM
lalahg lalahg is offline
Sorry for replying to such an old message, but this may be relavent for others searching through the posts:
Did you check the voltage after installing it? My engine ('92 3.8L) requires the voltage at idle to be between 0.36-0.46 volts.
I had to replace this sensor twice (coincedently right after a spring cleaning under the hood, hmmm). First was with an el-cheapo sensor, second with AC-Delco. I had to bend the arm on both to get the voltage under 0.46 volts!
