Old 07-16-2005, 12:25 PM
Poose22 Poose22 is offline
Send a message via AIM to Poose22
Left Blinker messed up??
this has been going on with my 95 grand prix for like a year at least, and ive never fixed it. a lot of the time when i go to put my left blinker on, the blinker will go on, but freeze and stay lite up. it will not blink. i was told that it could be a relay and read may be a fuse. anyone have this problem b4? whats the best way to attack this problem? thanx
Old 07-18-2005, 11:26 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Left Blinker messed up??
First off, check your bulbs. The blinker will not flash if a bulb is burnt out. On occasion, the bulb will break contact and then reconnect if the filiment is broken, and will a cause random malfunction of the turn signal.
Old 07-18-2005, 01:43 PM
i blinks sometimes. just not all the time.
Old 07-19-2005, 11:28 AM
richtazz's Avatar
The bulb filiment can connect and disconnect due to vibration, causing a random malfunction. By tapping on the bulb, you can see the filiment jump around if this is the case. If you replace the bulb and it still acts up, either the turn signal switch or the socket the bulb plugs in to is bad.
