| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
HeLP
CAR = 1992 Civic Si HB
Ever since I installed a front strut tower, and a rear lower tie bar, I've been getting a knocking sound from my car everytime I hit a bump, I dunno if it has anything to do with strut tower or the tie bar, or if it is just a coincidence, the noise I get is like a knocking and squeeking noise, from the right front side I think..., I took it to a mechanic, and said it seems like a sheet maetal hitting soething or being loose (meaning the exhaust), but he said to wait till the noise got worse, to find the exact source. I'm thinking the engine mounts are gone or the bushing on the engine mounts. I NEED EXPERTISE CAUSE IT"S REALLY BOTHERING ME....Does anyone know what the hell is this ? PLEASE HELP!!!!!! |
The strut bars add rigidy to the suspension. In other words, the suspension does not travel in the same way as it did before. Most likely, you have a suspension problem that did not show up before, because it was able to move further. Now that everything is 'tighter'...it is (probably) allowing it to pop more than before. I would look into the entire suspension system and go from there.
![]() PraxisPerformanceAutoworks LLC High performance autoparts & accessories. ________________________ sales and specials...Konig wheels, Accmat carpets, Thermal exhaust, DragunFire mufflers _____________________________ PraxisForums...informative information ____________________________ PraxisRacing is sponsoring. click for more info. _____________________________ see PureHonda in its original colors--> |
yea all that stuff stiffens the chassis which calls for a more "bumpier" ride in other words. There might be a problem somewhere else but i doubt it. Im sure it's probably the springs just making the noise from them trying to settle.
did you make sure that the bolts on the rear lower tie bar are not loose? That might be your problem
hey praxis, use a little bigger text, pretty please |
