Old 07-16-2005, 10:40 AM
J.Cutta's Avatar
J.Cutta J.Cutta is offline
How do Headers work on a Camaro
With paint and everything else out the way I'm starting to focus on my next mod Headers for a tbi 305. I brought the stock ralleys for it and the 16 inch wheels I'm gonna sell with that money I plan on buying headers and a y pipe. Also I must say with the 15 inch wheels I pick up speed alot fasters wheels lock up and everything. Back to the headers, Flowtech or maybe elberbrock. I seen some one post something on here in the past that would allow you to run both header pipes from the engine down one side and then in to two in the back. Or can a shop handle this for me and I"m worrying too much. I already have a catback system on the car that sounds good but i believe with headers they will be no use to me and I will need to muffler one for each pipe running from the headers.
http://www.cardomain.com/ride/631458
_______________
92 Camaro V8 TBI 305 with Dynomax 3" Catback Exhaust, ASCD Iroc Turbo Hood, Goodyear Triple Tread Tires, K&N Open Element, Cat Delete, WonderBar Steering Brace, 160 Thermostat
Old 07-16-2005, 11:00 AM
ct91rs ct91rs is offline
Re: How do Headers work on a Camaro
Are you saying that you want to run true dual exhaust? If you get headers and a y-pipe you could keep the cat-back system you have, and join the two. There isn't a lot of room under you car for dual exhaust front to rear, it can be done (custom made), but there won't be much ground clearance.
Old 07-16-2005, 11:07 AM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
headers are definatly worth the money, there was a drastic difference in both sound and performance when in installed my edelbrock TES headers. only catch is they are a pain in the ass to install, and you need a modified socket and wrench to get your spark plugs off. You can definatly do it yourself, i think Link did it in like two days or something. the edelbrock system is the header pipes, and the Y pipe, with the doughnuts and mounting hardware. i used the included exhaust gaskets but i would reccomend you buy some copper gaskets like i plan on upgrading to. the hardest part will be getting the old Y pipe off the catalytic converter so you can put the new Y pipe on, youll need a torch for that. do a search on here about the edeblrock TES headers, and youll find i did a lengthy post describing what i had to do to install them.
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 07-22-2005, 10:43 AM
FredCamaro FredCamaro is offline
Re: Re: How do Headers work on a Camaro
Hi guys,
I have a question about heders on a 91 z28 350, Is there a way to put heders on it and also keep the anti-polution system bolt on the original malifom.
Thanks
Old 07-22-2005, 12:39 PM
SpikeD SpikeD is offline
Send a message via AIM to SpikeD
yeap some companys make headers for the tpi with emissions in mind, havnt seen them in a while though, i do know there out there, ill be back with more info on this
1991 Z-28 350CID TPI
Old 07-22-2005, 03:05 PM
89IROC&RS's Avatar
my edelbrock TES headers were a direct swap and retained all the emissions equipment. only catch with these headers is you need to either modify or buy a modifed socket to get the plugs out of the heads. the primary pipes are routed directly over the spark plugs and there is no room for a socket and ratchet. and the plugs are sunk into the heads so you cant get a wrench on them. a modifed socket will allow you to use a wrech and socket combination to get the plugs out.
Old 07-22-2005, 06:15 PM
Savage Messiah's Avatar
Savage Messiah Savage Messiah is offline
Send a message via AIM to Savage Messiah Send a message via Yahoo to Savage Messiah
If I had a dollar for every post of 89 advertising TES headers...
97 Camaro - 2.077 60', 14.745 @ 92.20 - still down, one year later.
194k miles-160* thermo-V8 shocks/springs (V6 rear springs)-3" Magnaflow !cat (3" dynomax bullet) back-SLP CAI-stock boxed LCAs-poly tranny mount and torque arm bushing-custom HPTuners tuning-4.10s/eaton/TA girdle-3.5" alum DS-spohn LCA brackets-prostar skinnies
179.75 RWHP, 204.52 RWTQ
ON ITS WAY: MORE
R.I.P. Andy
87 Benz 190e - DD
01 EX250 - still gotta get my license for this thing
Old 07-22-2005, 07:28 PM
89IROC&RS's Avatar
lol what about vortec heads??????
Old 07-25-2005, 10:30 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
why would you need a torch for that? i used a sawsall and a hand saw to cut my exhaust and no problem. obviously the hand saw took longer than the 30seconds the sawsall took.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 07-25-2005, 10:44 PM
blindeyed's Avatar
blindeyed blindeyed is offline
eBay aDdict™
Send a message via AIM to blindeyed
Re: Re: Re: How do Headers work on a Camaro
Eh, I tried using a sawsall, but that thing jumped around everywhere. I ended up using a grinder, and that thing worked wonders. And that's what I used to cut the bolts in the flange that go from the y-pipe to the cat. You definately don't need a torch for that. Took me 2 seconds to get those bolts cut through.
- Jason
1995 Pontiac Firebird
User Guidelines | VB Codes Explained | AF Merchandise
"Each of us, is in the scheme of things, insignificant.
But millions of insignificant people, doing a tiny bit,
can add up to be a very significant force."
Old 07-26-2005, 11:15 AM
89IROC&RS's Avatar
well you could do it that way, i heated the Y-pipe to it would expand and then pulled it off the catalytic converter so that all the pipes were still uncut and intact.
