Old 04-26-2002, 01:15 AM
gwako gwako is offline
HeLP
CAR = 1992 Civic Si HB
Ever since I installed a front strut tower, and a rear lower tie bar, I've been getting a knocking sound from my car everytime I hit a bump, I dunno if it has anything to do with strut tower or the tie bar, or if it is just a coincidence, the noise I get is like a knocking and squeeking noise, from the right front side I think..., I took it to a mechanic, and said it seems like a sheet maetal hitting soething or being loose (meaning the exhaust), but he said to wait till the noise got worse, to find the exact source. I'm thinking the engine mounts are gone or the bushing on the engine mounts. I NEED EXPERTISE CAUSE IT"S REALLY BOTHERING ME....Does anyone know what the hell is this ?
PLEASE HELP!!!!!!
Old 04-27-2002, 04:42 AM
EightOhOne's Avatar
EightOhOne EightOhOne is offline
If it started after you installed the strut tower brace, thats probably the cause of it. I say take it off, and give it a test run and see if it clears up the problem.
Old 04-27-2002, 11:03 AM
But, has any one else experienced noises after they installed their strut towers...
Old 04-27-2002, 10:53 PM
5_LiTeR_EaTeR 5_LiTeR_EaTeR is offline
Send a message via AIM to 5_LiTeR_EaTeR
Ok heres what you do. First off do a bounce test and see if it will still make the noise. That means go to where you think the noise is coming from and bounce the car up and down really hard with your hands. If it makes the noise its probably a lower control arm bushing or sway bar bushings. What you do now is eliminate all the possibilties. Get some penetrating oil or some spray lubricant and sray every rubber bushing you see. DO EACH ONE AT A TIME and take it out for a test drive. that way you can narrow it down. You will still need to replace the bushing for whatever it is. If that doesn't work then try spraying the rubber seat to the coil spring. If thats not it.... look for anything unusual like wear or rub marks. strating cutting or moving things of you can see em. Hope that helps.
~Alex~
Old 04-27-2002, 10:57 PM
correction
*Start moving things or cutting things if you can see any of them*
hope that clarifies things.
help me help me help me please fuel pump help my90horsy Mustang Talk 16 12-05-2003 09:38 AM
help i need help i need help i need help i need help lamborghiniman Diablo 1 11-24-2003 01:33 AM
Help Help Help Help Help lewdaka03 Jetta/Vento/Bora 1 06-02-2003 01:57 PM
Help Help Help Help Help Help Help Help Help Help del_blond '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 3 04-05-2002 03:05 PM
Help Help Help !!!B20b!!! Help Help Help HondaCivic405 Engineering/ Technical 0 04-05-2002 01:51 PM
