AHH where is this water going?!
I've had my Bronco II for 3 years now. I found out shortly after buying it that is leaks like crazy in the back when it rains, gets washed, etc. I've tried all sorts of sealant to fix the problem. I was wondering if anyone else has had a problem with a leaky Bronco, and if so how did you fix it. ALSO, recently, the radiator water is decreasing rapidly ever day but I don't see any antifreeze leaking onto the ground. Where is it going?! Thanks
Is your passenger floorboard wet ?
have you filled your radiator up .. run it to operating temp..then look around for leaks ? might be heater core..might be over flow res. leak Clean the engine compartment with gunk and a pressure washer then wait till its dry..then run it again and see if anything is wet. It has to go somewere if its leaking..and I doubt its going into your engine..( without engine trouble symptoms ) |
